It is currently Mon Jun 30, 2025 3:11 pm
Reply to topic  [ 10 posts ]
 Tunnel hull with surface drive?
Post Tunnel hull with surface drive?
Have any of you guys tried running a Tunnel Hull boat with a surface drive? How does it perform? We have an 1860 Polar Kraft Mod V Tunnel Hull with a short shaft Yamaha 40hp. It will run in really shallow water, but it doesn't do well in stumps, mud, and trash.
Wed Jan 14, 2015 6:32 pm
Post Re: Tunnel hull with surface drive?
From what ive read it doesn't run well. Use the search feature. Lots of info.
1542 War Eagle with 25hp GDLT
Wed Jan 14, 2015 6:47 pm
If it worked well more people would have them.
Wed Jan 14, 2015 6:52 pm
It disturbs the water too much going to the prop.
17*38 Klibert 23GDLT
Wed Jan 14, 2015 6:58 pm
To get the belt housing out of the water stream, you have to have a short transom motor. Short transom motor on a tall transom boat means you lose the ability to dig. That's in addition to the crappy water it'll get with the tunnel.
35 GTR w/ 1860 GoDevil "Ironsides"
Wed Jan 14, 2015 7:55 pm
The belt housing is not in the water if the transom is the right height.
Wed Jan 14, 2015 8:00 pm
Thanks guys, it sounds like it will cavitate real bad.
Wed Jan 14, 2015 8:12 pm
Thu Jan 15, 2015 12:53 am
Thu Jan 15, 2015 4:14 am
My buddy ran a hyper drive on a tunnel hull gator trax boat and it ran just fine before the boat got all hooked to hell.
Fri Jan 16, 2015 7:00 am
Users browsing this forum: Majestic-12 [Bot] and 149 guests
