It is currently Sun Jun 29, 2025 2:06 am
Reply to topic  [ 49 posts ]  Go to page Previous  1, 2
 Foam removal
Post Re: Foam removal
Don't know why but the captions are correct but the pics are in the wrong order.
23hp GDLT on 16x38 GD boat
When up to your nose in shit, don't open your mouth.
Tue Mar 17, 2015 12:29 pm
Thanks for the pics, i like how you did that cap. Im considering just takeing everything out from the split seat back, then just lay a new sheet of aluminum down...I don't know how it would attach other that the sides though since i cant weld under the sheet of aluminum..rivets i guess?
Tue Mar 17, 2015 12:39 pm
Eat - Sleep - Hunt ! ! !
Tue Mar 17, 2015 12:55 pm
Tue Mar 17, 2015 2:00 pm
Just messing with you.....
Hope it turns out like you want.....
The catwalk idea is a pretty good one though to keep
from weakening your transom and add functionality....
I love my catwalks - can't imagine a MM hull without them now....
Tue Mar 17, 2015 2:56 pm
If you're going to lay down a sheet over the whole back end of the boat for flooring, drill 7/16" holes and spot weld it to the stringers. It will be better than rivets and add a certain amount of rigidity (not much, but every bit helps) Id leave the edges open like in front of the split seats for gutters. Or you could run it all the way to the sides of the boat and stitch weld it to the sides. You could use a sheet of .100 or .125 for the floor.
-Custom pool noodle
-stage 4 water wings
Tue Mar 17, 2015 3:44 pm
I Bet those catwalks are nice. Did you have to cut a whole sheet of aluminum to add them?
And thanks thats what i was planning on doing in the back
Tue Mar 17, 2015 3:50 pm
Tue Mar 17, 2015 3:59 pm
Tue Mar 17, 2015 8:51 pm
Users browsing this forum: No registered users and 153 guests
