It is currently Fri Jun 27, 2025 6:42 pm
Reply to topic  [ 8 posts ]
 Need bimini hardware help
Post Need bimini hardware help
I'm in the process of retro-fitting an old blind that was made with 1" EMT. I want to remount the blind to the boat using bimini fittings but I'm having a helluva time finding some the right size that will work with 1" tubing. I need either a male end cap that will fit into a 1" I.D. or a female fitting that will fit over 1 1/8" O.D. Does anyone make this size of fitting?
1860 Prodigy
Mon Jun 29, 2015 4:54 pm
Post Re: Need bimini hardware help
What many have done is close the end of the EMT (either a vise or hammer), grind it round and drill and hole through it. Then mount a u bracket to the boat with a bolt through it. An assortment of U brackets and bolts can be found at any hardware store for cheap. Bimini top fittings are way more expensive than they should be...
Or just get a bracket wide enough for the EMT and don't close the end... either way... cinch pins or bolts...
Tue Jun 30, 2015 4:35 am
^^^^ this just saved you $$$ and 7/8 is the largest hardware I've seen ( fit 3/4 emt)
http://www.gatorglide.com/
gatorheads@comcast.net
Tue Jun 30, 2015 4:37 am
Yep got tired of spending the money on bimini hardware. Here is how i set up a blind years ago with emt and made it removable. I dont use a blind anymore though..
If you do make it removable with C-clamps, I have found that riveting the clamp to the emt works better than bolting through.
Tue Jun 30, 2015 7:11 am
1860 Prodigy
Tue Jun 30, 2015 8:03 am
Tue Jun 30, 2015 8:37 am
That's what I'm gonna end up doing I guess. Thought maybe I could find some bimini fittings in 1".
1860 Prodigy
Wed Jul 01, 2015 7:38 am
Thu Jul 02, 2015 5:14 am
Users browsing this forum: No registered users and 137 guests
