It is currently Thu Jun 26, 2025 12:01 pm
Reply to topic  [ 6 posts ]
 Wiring/receptacle for headlights
Post Wiring/receptacle for headlights
What's everybody using for their headlight plug? A regular 12v socket type plug would work as far as load but seems like it would have a tendency to get wet. My wires are already ran and there is a hole in the deck. Just need to put a plug-in there. A 2 wire trolling motor plug would work too but I think that would be overkill. I just want something as weatherproof as possible. Ideas?
This one would work fine, looking for all black though.
http://www.blackbearsportinggoods.com/m ... R&click=12
-Custom pool noodle
-stage 4 water wings
Sun Dec 13, 2015 10:29 pm
Post Re: Wiring/receptacle for headlights
i use the marinco three pin plug that twist locks into place, they are a little expensive, but well worth it in my opinion.
Mon Dec 14, 2015 3:56 am
I use a 2 pin connector, cheap and has held up well to the elements. No issues out of it, very cheap too.
https://jet.com/product/detail/d8428311 ... AqSb8P8HAQ
Any auto parts store should have it.
Mon Dec 14, 2015 4:24 am
I ended up just getting a plain 12v plug with a mounting flange. It has a rubber cap and I plan on drilling a couple holes in the bottom so if it does happen to get water in it, it'll drain. Best part it's a pretty cheap setup so if it craps out or corrodes real bad, I can replace it for less than $10. My light will have a male 12v end on it that I'll be able to use anywhere. The connector is good for 15a, circuit is fused for 10.
-Custom pool noodle
Tue Dec 15, 2015 10:30 pm
Wed Dec 16, 2015 5:29 am
http://www.marinco.com/en/12vcp
This is the one I believe everyone uses. I even put it one on the end of my hand held so it doesn't come loose when I am using it
Wed Dec 16, 2015 6:21 am
Users browsing this forum: No registered users and 191 guests
