KaCajun Boy
Joined: Tue Nov 01, 2011 2:43 am Posts: 179 Location: SELA
 Re: Foam removal
Don't know why but the captions are correct but the pics are in the wrong order.
_________________ 23hp GDLT on 16x38 GD boat When up to your nose in shit, don't open your mouth.
Tue Mar 17, 2015 12:29 pm |
Quack N Stack
Joined: Sat Dec 15, 2012 9:43 pm Posts: 2225 Location: Baytown, Tejas
 Re: Foam removal
Thanks for the pics, i like how you did that cap. Im considering just takeing everything out from the split seat back, then just lay a new sheet of aluminum down...I don't know how it would attach other that the sides though since i cant weld under the sheet of aluminum..rivets i guess?
Tue Mar 17, 2015 12:39 pm |
Gigafowl
 Re: Foam removal
Tue Mar 17, 2015 12:55 pm |
Quack N Stack
 Re: Foam removal
Tue Mar 17, 2015 2:00 pm |
Gigafowl
 Re: Foam removal
Just messing with you.....
Hope it turns out like you want.....
The catwalk idea is a pretty good one though to keep from weakening your transom and add functionality....
I love my catwalks - can't imagine a MM hull without them now....
Tue Mar 17, 2015 2:56 pm |
SETx Longtail
 Re: Foam removal
If you're going to lay down a sheet over the whole back end of the boat for flooring, drill 7/16" holes and spot weld it to the stringers. It will be better than rivets and add a certain amount of rigidity (not much, but every bit helps) Id leave the edges open like in front of the split seats for gutters. Or you could run it all the way to the sides of the boat and stitch weld it to the sides. You could use a sheet of .100 or .125 for the floor.
_________________ #CFFITR
Tue Mar 17, 2015 3:44 pm |
Quack N Stack
 Re: Foam removal
I Bet those catwalks are nice. Did you have to cut a whole sheet of aluminum to add them?
And thanks thats what i was planning on doing in the back
Tue Mar 17, 2015 3:50 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
 Re: Foam removal
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
Tue Mar 17, 2015 3:59 pm |
Gigafowl
 Re: Foam removal
Tue Mar 17, 2015 8:51 pm |
