New Houseboat Build
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=45986
Page 1 of 4
Author:  bengtr35 [ Wed Oct 02, 2013 1:06 pm ]
Post subject:  New Houseboat Build
Well with the server crashed my last topic was deleted.
Looks like I will go with Permafloats and have a few questions to the owners that have used this. I think I will make it 24x50. Going to go with 5ea. 8' sections on each side with a 8' water tank in the middle. Will also build a 3' aluminum rake in the front.
My question and why I always stayed away from the permafloats is every house boat I have seen that has been a few years old always had a sag in the middle. So being that would be the first one I build on floats would this be good:
3"x3"x1/4" angle to saddle the tanks and then on top on the angle a 2"x4"x1/4" t-bar. Then I would weld some angle iron to put the 2"x12"x24' floor joist every 16".
Do you think this would be good or do I need to go even stronger?
Author:  bengtr35 [ Wed Oct 02, 2013 1:26 pm ]
Post subject:  Re: New Houseboat Build
Also has any one went with the 32" tall apposed to the 24"? Or everyone is fine with the 24"?
Author:  Fowlmood [ Wed Oct 02, 2013 1:45 pm ]
depending on the size of the camp the 24's may not be enough it's not much more expensive for the 32's. what size are your porches going to be.
Author:  bengtr35 [ Wed Oct 02, 2013 2:43 pm ]
Author:  Fowlmood [ Wed Oct 02, 2013 3:39 pm ]
i would also look into using 6 floats each side which will give you 48' of pontoon
Author:  naj [ Wed Oct 02, 2013 9:06 pm ]
Some companies are offering 10' floats.
Go with 5 10' X 48" X 32". This would make your 50 foot.
Dont be cheap on flotation. I am tired of seeing practically every fucking camp with added flotation.
Author:  banded-mallard [ Thu Oct 03, 2013 5:23 am ]
Author:  Fowlmood [ Thu Oct 03, 2013 5:35 am ]
Author:  msm8281 [ Thu Oct 03, 2013 6:04 am ]
Aluminum will be more expensive. You will also have to add anodes and have to worry about electrolysis.
Author:  bengtr35 [ Thu Oct 03, 2013 7:14 am ]
Dose any one has any pictures or drawings of there houseboat in floats. Also while building what you would different. I have a houseboat and will be at wax lake this year but want to start building a bigger one for next year.
Author:  Fowlmood [ Thu Oct 03, 2013 7:37 am ]
you are welcomed to come look at mine and ill tell you what i would do diffrent im at piles 70-72 at the wax.
Author:  Fowlmood [ Thu Oct 03, 2013 7:38 am ]
pm me your # i will send you pics as i dont know how to put pics on here
Author:  CJB [ Thu Oct 03, 2013 8:04 am ]
Check out how Uncle J did his floats... viewtopic.php?f=8&t=37245
Author:  bengtr35 [ Thu Oct 03, 2013 10:06 am ]
Fowl,
Thanks and I will stop by when I see people at your camp. How did you brace it? You can e-mail or text me pictures: ben.sanamo@chouest.com or text at 985-677-2473
CJB,
I saw that build but I do not know how it will not sag over time so thats why I am going all my research and want to over build it so I will not have any regrets.
Also no one as answered my question about using 3x3x1/4" angle with 2x4x1/4 Ibeam on top. Do you think it would be strong enough?
Author:  Fowlmood [ Thu Oct 03, 2013 10:30 am ]
Author:  bengtr35 [ Tue Nov 05, 2013 4:04 pm ]
Just placed my order. Going with 15 4x8 floats and 2 4x6 floats. Going to have a 14' water tank in the center pontoon. The outer pontoons will will have 5ea 8' floats, 1ea 6' float, 2' aluminum rake, and a 8' aluminum mercruiser pod on the back. The total length will be 56' The center pontoon will have 5 8' floats, a 2' rake and a 14' aluminum water tank in the center.
Should not have a problem with floatation.
Planning to have a 20x38 house and 8' front porch and a 10' back porch. Plans may change a little once the build starts.
Author:  msm8281 [ Tue Nov 05, 2013 6:15 pm ]
I would rethink the 10 foot porch.Mine was 10' and it wasn't enough. I figure that I spend most of my time outside hanging out. Once you put a few chairs, coolers, and people that 10' shrinks quite fast.
Author:  dfou [ Tue Nov 05, 2013 6:34 pm ]
Author:  msm8281 [ Tue Nov 05, 2013 6:41 pm ]
My old porch was 10x25. You can see where the roof stops. That was the original porch. Its now 20x25. Im sure glad I extended it while it was dry docked.uploadfromtaptalk1383698481810.jpg
Author:  bengtr35 [ Tue Nov 05, 2013 7:00 pm ]
Author:  msm8281 [ Tue Nov 05, 2013 7:13 pm ]
This is the only other picture I have. The bottom looks just like the top. It's bolted on in the middle with a support from the bottom back to the frame.uploadfromtaptalk1383700368986.jpg
Author:  naj [ Tue Nov 05, 2013 7:16 pm ]
If you are putting a motor save all of your receipts. You will have to register it as a power driven vessel with LDWF.
Author:  bengtr35 [ Thu Nov 07, 2013 1:52 pm ]
Well the 18 wheeler dropped them off today.
Author:  cr244 [ Fri Nov 08, 2013 7:00 pm ]
msm8281 that camp is bad ass show more pics. and some of the inside also. PLEASE! and bengtr35 be sure to post your build with good pics. also. i have the ability to build a camp but it would have to set in the yard. LOL no place to float it. the camps i see on this site are bad ass to me. i really like looking at them.
Author:  OwenDickeson [ Fri Nov 08, 2013 7:11 pm ]
Do most of yalls houseboats not have motors?
Author:  msm8281 [ Fri Nov 08, 2013 7:15 pm ]
Yes...most don't have motors. Most aren't moved around much, maybe twice a year.
Author:  msm8281 [ Fri Nov 08, 2013 7:18 pm ]
Author:  OwenDickeson [ Fri Nov 08, 2013 7:24 pm ]
Author:  msm8281 [ Fri Nov 08, 2013 7:29 pm ]
Author:  cr244 [ Fri Nov 08, 2013 7:54 pm ]
msm thanks for pics. my wifes parents have 2 houses on lake martin in alabama and a house in destin fl. i have a lot that is 1.3 acres on the tallapoosa river in alabama. i would build a camp in a hurry if i could have 1 on the river.
Author:  I make oil [ Sat Nov 09, 2013 2:19 am ]
I post on another site and we have started a forum just for houseboats/camps. I have had trouble finding much info around the internet on them so thought it would be good to have a place to collect information. It would be helpful and interesting to others if you could post your build thread there too.
http://www.thejump.net/board/viewforum. ... 70e5ffb5dd
Author:  cr244 [ Sat Nov 09, 2013 12:12 pm ]
i make oil, thanks man that site is cool and your camp is nice. i will keep checking in to see if any new camps are posted
Author:  Bad Boy [ Sat Nov 09, 2013 11:59 pm ]
Here is a Link to my Build with Pics.
viewtopic.php?f=4&t=30135&p=625990#p625990
Author:  cr244 [ Sun Nov 10, 2013 9:40 am ]
Author:  I make oil [ Mon Nov 11, 2013 5:55 am ]
Author:  bengtr35 [ Mon Nov 18, 2013 10:12 am ]
Does any one know who's this house boat for?
Author:  msm8281 [ Mon Nov 18, 2013 10:14 am ]
Author:  msm8281 [ Mon Nov 18, 2013 10:16 am ]
Looka like its in bird island chute now.
Author:  bengtr35 [ Mon Nov 18, 2013 10:25 am ]
If any one knows the owner please let me know. I saw it on another forum that someone had posted. It very similar to the one I want to build.
Author:  msm8281 [ Mon Nov 18, 2013 10:30 am ]
Page 1 of 4 All times are UTC - 6 hours
