Older Gator Tail and question on rig
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=46718
Author:  luv2cmwork [ Thu Oct 24, 2013 1:03 pm ]
Post subject:  Older Gator Tail and question on rig
I hunt hard dirt bottom. Anywhere from 4 foot or more, to as little as 6 inches. No problem with an outboard in the deeper depths, but LOTS of weeds/grasses in the middle depths, to shallows make an outboard frustrating. No mud, to speak of...at least not the "boggy" type mud I see on videos.
I'm looking at purchasing a complete rig. A 1648 rig, with a older (could be first generation maybe?) 23 hp Gatortail. It appears to be a flat bottom (no mod v front) jon boat.
Keeping in mind my environment of vegetation mostly, is the rig suitable? Also, any issues with the first Gator tails? This seems to be an older model.
Thanks!
Author:  btmannin [ Thu Oct 24, 2013 1:08 pm ]
Post subject:  Re: Older Gator Tail and question on rig
got any pictures?
Author:  luv2cmwork [ Thu Oct 24, 2013 2:50 pm ]
Here is one...about the only one I have.
Author:  btmannin [ Thu Oct 24, 2013 2:58 pm ]
Does the Lu bracing look like this? Just tryin to get an idea of how old it is
Author:  luv2cmwork [ Thu Oct 24, 2013 8:12 pm ]
Here is the best picture I can provide
Author:  Woodiebuster [ Thu Oct 24, 2013 9:42 pm ]
What kinda load are you carrying?
Author:  luv2cmwork [ Fri Oct 25, 2013 6:31 am ]
1 to 3 guys and gear. 3 normally, with a 700-800 lb load. Perhaps 4 on rare occasions...very rare.
Author:  eljefe [ Fri Oct 25, 2013 6:56 am ]
Your gonna want more power....
sent from the former Republic of Texas.
Author:  139sst [ Fri Oct 25, 2013 4:57 pm ]
Luv2cmwork, your first sentence tells me you need a longtail. Shallow water and hard bottom is longtail territory.
Author:  Woodiebuster [ Fri Oct 25, 2013 6:14 pm ]
That rig will be a turd with the mentioned load, gunna want a 35 hp on a 18' hull
Bite the bullet now and save some money in the end
Author:  luv2cmwork [ Sun Oct 27, 2013 8:10 pm ]
Well..I think you guys talked me out of it. The rig is a several hours away and I'm concerned the Gator Tail motor isn't particular good in weeds and less so on hard bottom.
I think I'll stick with the outboard for awhile. Maybe a SD is a poor choice for me.
Thanks for your replies.
Author:  luv2cmwork [ Mon Oct 28, 2013 5:21 pm ]
I should have added, I only motor about 1.5 miles at the very most..usually less than a mile. Speed isn't an issue, but getting there is. Sometimes, it's hard to find the deep channel and I thought the GT would "make a path" through the vegetation.
We've hunted 4 out of 1652 with a 25 horse outboard with speeds of 17 mph. I thought the 23 would get me at least 14 with 2...maybe 3 guys plus gear.
I'm currently running a 9.9 outboard on a 1652 and it works, but a little slow and I struggle with the vegetation.
I just wondered how the GT would compare, but I'm still hearing that it wouldn't be that much of an advantage with the hard bottom and heavy vegetation. Is that about right?
