16 x 46 Russian Gator Tail 35hp GTR Hoty's Cam https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=47011 |
Page 1 of 2 |
Author: | dguidry [ Sun Nov 03, 2013 5:08 pm ] |
Post subject: | 16 x 46 Russian Gator Tail 35hp GTR Hoty's Cam |
As most of you know I stepped up to this from a 15 x 40 Custom Wooden Boat with a GTR23 , Hoyt's cam, Decked heads, Mikuni Carb, and Crossover Muffler. The 35hp in its current configuration is a beast on the hole shot and load carrying compared to the highly modified 23hp. It idles very nicely and there is snappy acceleration over the whole throttle range. I did not break out the gps to clock speed, but I know I'm haulin' ass in this rig plenty enough. She is still porpoising at full throttle though with just me in the boat. I never got above 3250 RPMS. Top trim attitude still leaves too much prop in the water so will have to experiment with next highest transom angle notch hole. I think that since this is a 16' boat she sits low so thrust angle needs so be adjusted accordingly. I had beads welded on bottom near transom but that did not seem to cure the porpoising altogether, though it helped. I don't plan to run this rig full throttle all the time anyway as she is plenty fast at 3/4 throttle. With new Mikuni and adjusted transom notch setup I should be able to bump the coil limiter at 4300 rpms easily if I need to. Seems to bog in heavy mud. New Mikuni carb should take care of that. My prop is a speed prop. I have another new Gator tail stock I will install for later comparison. Going over stumps in my little boat was a thrill every time but with this hull I was up and over with ease. Initially I installed my GTR23 on this hull and ran it in the bayou until I discovered the crankcase was cracked. That combo would have been fine but with the 35hp there is almost no loss in speed and hole shot with more load. Overall, very happy with this setup. Thanks Gator Tail and Calen's Engine. |
Author: | mizzippi jb [ Sun Nov 03, 2013 5:20 pm ] |
Post subject: | Re: 16 x 46 Russian Gator Tail 35hp GTR Hoty's Cam |
So you have a stage 2 motor with 4300 coils and plan on running it in the mid 3000's? Sounds like you wasted a ton of money on mods to me (on something a stock motor will do with ease) Sent from my GT-P5113 using Tapatalk 2 |
Author: | mizzippi jb [ Sun Nov 03, 2013 5:37 pm ] |
On second thought, I'm sure you have some backwards libtard justification of why. Sent from my GT-P5113 using Tapatalk 2 |
Author: | dguidry [ Sun Nov 03, 2013 5:40 pm ] |
Author: | diddyduck [ Sun Nov 03, 2013 5:51 pm ] |
Author: | msm8281 [ Sun Nov 03, 2013 5:53 pm ] |
Must be the "HOTY" cam |
Author: | mizzippi jb [ Sun Nov 03, 2013 5:58 pm ] |
Author: | Kmoppert [ Sun Nov 03, 2013 6:05 pm ] |
In Communist Russia you do not race boat, boat race you. |
Author: | dguidry [ Sun Nov 03, 2013 6:20 pm ] |
I've got vid. |
Author: | mizzippi jb [ Sun Nov 03, 2013 6:22 pm ] |
Author: | dguidry [ Sun Nov 03, 2013 6:26 pm ] |
Author: | Old School [ Sun Nov 03, 2013 6:28 pm ] |
Did u get new knee pads too. |
Author: | mizzippi jb [ Sun Nov 03, 2013 6:41 pm ] |
Ill be the first to call outright bullshit Sent from my GT-P5113 using Tapatalk 2 |
Author: | dguidry [ Sun Nov 03, 2013 6:41 pm ] |
http://youtu.be/GXyHHeJC9eQ |
Author: | dguidry [ Sun Nov 03, 2013 6:45 pm ] |
I told you so!! |
Author: | VooDoo Daddy [ Sun Nov 03, 2013 6:46 pm ] |
why is it a "Russian" gator tail? |
Author: | mizzippi jb [ Sun Nov 03, 2013 6:51 pm ] |
I didnt see you walk away from the boat beside you. And furhermore, if the boat beside you was running wot, you weren't running 3800 rpms. I hope you have enough sense to realize that either you were running a lot higher rpms or your tiny tach is way off. (Or was it a 27 hp pd?) Sent from my GT-P5113 using Tapatalk 2 |
Author: | dguidry [ Sun Nov 03, 2013 6:53 pm ] |
Author: | mizzippi jb [ Sun Nov 03, 2013 6:54 pm ] |
Author: | dguidry [ Sun Nov 03, 2013 6:55 pm ] |
Author: | dguidry [ Sun Nov 03, 2013 7:04 pm ] |
You see any passengers in the other boats? |
Author: | Woodiebuster [ Sun Nov 03, 2013 7:11 pm ] |
So, describe how to me how your 1/8" boat is a "tank" |
Author: | dguidry [ Sun Nov 03, 2013 7:23 pm ] |
Author: | mizzippi jb [ Sun Nov 03, 2013 7:25 pm ] |
.500 guage hull, huh? Nice. It may be time for me to follow suit ofthe others. Sent from my GT-P5113 using Tapatalk 2 |
Author: | dguidry [ Sun Nov 03, 2013 7:35 pm ] |
Author: | cupped up [ Sun Nov 03, 2013 7:48 pm ] |
Since you said its a speed prop, if its a 12P prop and you were turning 3850 with average slip it is possible that you were walking that PD rig, as much as I hate to admit it. You were probably running around 32ish at 3850 with average slip numbers. And him with heads and mikuni was probably around 30-31. You haven't put a GPS on it? |
Author: | dfou [ Sun Nov 03, 2013 7:49 pm ] |
I offered to build you a boat, that wouldn't porpoise at half throttle, if you woulda let me burn that pos wood "custom" skiff Sent from my iPhone using |
Author: | diddyduck [ Sun Nov 03, 2013 10:29 pm ] |
nice dguid...but i still call bs on those rpms and running that well.. |
Author: | cupped up [ Mon Nov 04, 2013 12:24 am ] |
Author: | diddyduck [ Mon Nov 04, 2013 6:49 am ] |
Author: | Full Throttle [ Mon Nov 04, 2013 7:33 am ] |
Can't see the comments but did Guidry buy a Russian GTR because he prefers a country formerly run by communists??? His political views would suggest that. |
Author: | dguidry [ Mon Nov 04, 2013 7:34 am ] |
The video does not lie. Don't know what y'all's problem is with this. Even if I'm just keeping up I've still got more than twice the weight in occupants. |
Author: | North LA Hunter [ Mon Nov 04, 2013 7:49 am ] |
I would love to see more pictures of this .500 thick hull that you speak of. Sent from my beeper. |
Author: | dguidry [ Mon Nov 04, 2013 8:06 am ] |
Author: | Goose Crumpler [ Mon Nov 04, 2013 8:14 am ] |
Author: | dguidry [ Mon Nov 04, 2013 8:21 am ] |
Author: | pokey79 [ Mon Nov 04, 2013 8:57 am ] |
I want to race!!!! ![]() |
Author: | deltaduckmaster [ Mon Nov 04, 2013 9:21 am ] |
What's the funniest is Guidry got you fuckers dangling by a string and y'all can't figure it out. Lol |
Author: | deltaduckmaster [ Mon Nov 04, 2013 9:22 am ] |
My boat ran 33.2 at 4160 rpm. Please tell me how that was possible with a stock prop |
Author: | Jamie B. [ Mon Nov 04, 2013 9:25 am ] |
Page 1 of 2 | All times are UTC - 6 hours |
