1646 skiff with a 23 swomp https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=47174 |
Author: | soulrebel [ Thu Nov 07, 2013 11:01 pm ] |
Post subject: | 1646 skiff with a 23 swomp |
Looking for some expert opinions. I'm going to have a custom skiff built here in the next month. Wondering what size would be best for the back water 23. I'm going with 3/16 bottom and 1/8 sides. I've owned larger boats with surface drives, I'm going back to a longtail. Wondering if anybody has ran one of those motors on a similar sized hull? Just want to know performance numbers and draft characteristics. Any opinions or facts would be great. |
Author: | 139sst [ Fri Nov 08, 2013 10:32 am ] |
Post subject: | Re: 1448 1548 1546 1646 1648 skiff with a 23 swomp |
I am running a 1542 true flat square chine with a gd 23 lt. Empty, about 22, fully loaded in duck hunt mode with two men, about 17. A 1648 true flat light weight jon should be the same loaded down maybe 1mph down if empty. Do not buy a welded mv hull with your longtail. It will be a pig. Welded flat bottom is fine if light weight. IF I were doing it over again I would buy the Go Devil 18x38 round chine. |
Author: | Trousertrout [ Fri Nov 08, 2013 3:40 pm ] |
What did Arlen recommend? And did he start building boats? I would think 16 range would be perfect. You could even go 17. I think woodie buster will chime in. He is getting good speeds. |
Author: | soulrebel [ Fri Nov 08, 2013 4:10 pm ] |
Author: | Trousertrout [ Fri Nov 08, 2013 4:39 pm ] |
Definitely go 16. I think you might loose speed and draft more if you went 15 or 14 |
Author: | FRANKtheTAU [ Fri Nov 08, 2013 4:41 pm ] |
I'm running a 1648 War Eagle. As far as production hulls go, I love it. If I was having a custom hull built, it'd be a 1646, maybe 1644. My 23 SWOMP blows me away on my War Eagle. I'd love to try it on a good mud hull though! |
Author: | OlSchool [ Fri Nov 08, 2013 8:44 pm ] |
I think 16x42 is a really good match for the 23. I run a 16x42 weldbilt. Not a true flat bottom but it gets the job done running 21 with two 190 lb guys. |
Author: | OlSchool [ Fri Nov 08, 2013 8:46 pm ] |
I think 16x42 is a really good match for the 23. I run a 16x42 weldbilt. Not a true flat bottom but it gets the job done. 23 GDLT running 20.5 - 21.5 with two 190 lb guys. |
Author: | soulrebel [ Sat Nov 23, 2013 7:45 pm ] |
Decided to go with a 16x46 skiff 3/16 bottom 1/8 sides 48" front deck with dry storage 16" transom 23 hp ss backwater swomp Pics to come later. |
Author: | FRANKtheTAU [ Sat Nov 23, 2013 8:23 pm ] |
You're gonna love that SWOMP! |
Author: | soulrebel [ Mon Nov 25, 2013 7:21 pm ] |
here are some pics of the build |
Author: | soulrebel [ Mon Nov 25, 2013 7:28 pm ] |
more |
Author: | da go get'er [ Mon Nov 25, 2013 7:31 pm ] |
looks good. how much rake in the front? |
Author: | soulrebel [ Mon Nov 25, 2013 7:40 pm ] |
Don't know that. I'll have to ask. |
Author: | soulrebel [ Tue Nov 26, 2013 3:27 pm ] |
Author: | da go get'er [ Tue Nov 26, 2013 7:54 pm ] |
