It is currently Sun Jul 20, 2025 1:41 pm
Reply to topic  [ 16 posts ]
 1646 skiff with a 23 swomp
Post 1646 skiff with a 23 swomp
Looking for some expert opinions. I'm going to have a custom skiff built here in the next month. Wondering what size would be best for the back water 23. I'm going with 3/16 bottom and 1/8 sides. I've owned larger boats with surface drives, I'm going back to a longtail. Wondering if anybody has ran one of those motors on a similar sized hull? Just want to know performance numbers and draft characteristics. Any opinions or facts would be great.
Thu Nov 07, 2013 11:01 pm
Post Re: 1448 1548 1546 1646 1648 skiff with a 23 swomp
I am running a 1542 true flat square chine with a gd 23 lt. Empty, about 22, fully loaded in duck hunt mode with two men, about 17. A 1648 true flat light weight jon should be the same loaded down maybe 1mph down if empty. Do not buy a welded mv hull with your longtail. It will be a pig. Welded flat bottom is fine if light weight. IF I were doing it over again I would buy the Go Devil 18x38 round chine.
Fri Nov 08, 2013 10:32 am
What did Arlen recommend? And did he start building boats? I would think 16 range would be perfect. You could even go 17. I think woodie buster will chime in. He is getting good speeds.
23 swomp/ 1542 tracker
Fri Nov 08, 2013 3:40 pm
Fri Nov 08, 2013 4:10 pm
Definitely go 16. I think you might loose speed and draft more if you went 15 or 14
Fri Nov 08, 2013 4:39 pm
I'm running a 1648 War Eagle. As far as production hulls go, I love it. If I was having a custom hull built, it'd be a 1646, maybe 1644. My 23 SWOMP blows me away on my War Eagle. I'd love to try it on a good mud hull though!
Fri Nov 08, 2013 4:41 pm
I think 16x42 is a really good match for the 23. I run a 16x42 weldbilt. Not a true flat bottom but it gets the job done running 21 with two 190 lb guys.
Fri Nov 08, 2013 8:44 pm
I think 16x42 is a really good match for the 23. I run a 16x42 weldbilt. Not a true flat bottom but it gets the job done. 23 GDLT running 20.5 - 21.5 with two 190 lb guys.
Fri Nov 08, 2013 8:46 pm
Decided to go with a 16x46 skiff
3/16 bottom
1/8 sides
48" front deck with dry storage
16" transom
23 hp ss backwater swomp
Pics to come later.
Sat Nov 23, 2013 7:45 pm
You're gonna love that SWOMP!
Sat Nov 23, 2013 8:23 pm
here are some pics of the build
Mon Nov 25, 2013 7:21 pm
more
Mon Nov 25, 2013 7:28 pm
looks good. how much rake in the front?
17*38 Klibert 23GDLT
Mon Nov 25, 2013 7:31 pm
Don't know that. I'll have to ask.
Mon Nov 25, 2013 7:40 pm
Tue Nov 26, 2013 3:27 pm
Tue Nov 26, 2013 7:54 pm
Users browsing this forum: No registered users and 108 guests
