12x36 Back water with 2100 Copperhead https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=48356 |
Author: | thirdtimesacharm [ Mon Dec 16, 2013 12:27 pm ] |
Post subject: | 12x36 Back water with 2100 Copperhead |
Headed to the water to get some numbers on the back water with 2100 Copperhead. |
Author: | Bigbuckfever [ Mon Dec 16, 2013 1:46 pm ] |
Post subject: | Re: 12x36 Back water with 2100 Copperhead |
Cool little rig! |
Author: | fowllife08 [ Mon Dec 16, 2013 2:35 pm ] |
Thing flys r what? |
Author: | thirdtimesacharm [ Mon Dec 16, 2013 3:22 pm ] |
Just got back from test run...... Ran 23 consistent w/ just me @ 230lbs 21 w/ me and 125lb passenger 19 w/ me and 250lb passenger |
Author: | North LA Hunter [ Mon Dec 16, 2013 3:33 pm ] |
What is a 2100 motor? Sent from my beeper. |
Author: | thirdtimesacharm [ Mon Dec 16, 2013 4:10 pm ] |
2100 series Briggs. It's rated by torque instead of ponies but around 13 hp |
Author: | Frog [ Mon Dec 16, 2013 5:03 pm ] |
That is cool as hell! Looks like you could put it the back of a pick up and go anywhere. 2 palm frond camo |
Author: | thirdtimesacharm [ Tue Dec 17, 2013 6:52 pm ] |
Layin paint |
Author: | thirdtimesacharm [ Wed Dec 18, 2013 4:39 pm ] |
Time for hydro turf...... |
Author: | txkingfisher [ Wed Dec 18, 2013 6:06 pm ] |
What's with the half pipe runners/stringers on the bottom? Why aren't they on the inside? Other than that, this thing looks like the ultimate lightweight rig. |
Author: | thirdtimesacharm [ Wed Dec 18, 2013 7:11 pm ] |
We only put them on the backwater because it's .090" so you can drag it over land or behind a 4wheeler and not destroy the bottom. |
Author: | txkingfisher [ Wed Dec 18, 2013 8:18 pm ] |
Aaaaha! Makes sense..... |
Author: | thirdtimesacharm [ Thu Dec 19, 2013 1:33 am ] |
Done! |
Author: | muddoctor [ Thu Dec 19, 2013 11:31 am ] |
Nice looking boat, why so slow??? Our 1236 Prowler and our 1440 Lite Jon will run 26-28 mph one man and 22-24 all day with two men and that motor? Might need to talk with Copperhead and look at a different prop. PW |
Author: | cr244 [ Thu Dec 19, 2013 6:50 pm ] |
awesome little boat corey another fine job! |
Author: | thirdtimesacharm [ Fri Dec 20, 2013 7:36 am ] |
Mud doctor we had an idle issue on this one when we first cranked it up and initially backed off the throttle cable thinking it was pulled to tight. I didn't realize we never readjusted the cable till final assembly. I noticed on that test run it didn't sound like it was turning enough rpm's at wot so I believe the adjustment cured it. The idle issue was the factory throttle arm rubbing the plastic housing if y'all ever encounter one that won't idle down. Hope to do some more testing this weekend. |
Author: | ho52 [ Fri Dec 27, 2013 10:17 pm ] |
What's the boat and setup run??$$ |
Author: | thirdtimesacharm [ Fri Dec 27, 2013 10:23 pm ] |
$6,995 plus tax |
Author: | MNGunner [ Sat Dec 28, 2013 6:18 pm ] |
Author: | thirdtimesacharm [ Sat Dec 28, 2013 6:30 pm ] |
Here's one without...... And a huntdeck. |
Author: | koonce727 [ Mon Dec 30, 2013 12:21 pm ] |
Nice little set-up, any update on speed after re-adjusting the throttle? |
Author: | thirdtimesacharm [ Mon Dec 30, 2013 2:26 pm ] |
Haven't been back to the water. The one chance we had Mother Nature decided otherwise lol. |
