quack-quack
 Wiring thin wire
So I got some cheapy led strips for my buddies boat. We tried to wire them up but the wire on these strips are super thin.. A) what gauge should I be using to connect to the strip B) how do I connect the two? Without electrical tape!
Fri Dec 27, 2013 10:54 pm |
msm8281
 Re: Wiring thin wire
Not sure if its the best way but...I stripped about 3/4" of the thin wire. Then I folded it 3 times so it would fit in a butt connector and I could make a good crimp. BTW I used 14g .
Fri Dec 27, 2013 11:03 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
Either a reducing connector or a terminal block. You could also solder them together and cover the splice with marine shrink wrap.
Fri Dec 27, 2013 11:22 pm |
bmartina
Joined: Tue Dec 25, 2012 11:27 pm Posts: 641 Location: Apalachicola Fl
Look at scotch locks that's what I call them wired my old duck boat with them works from 19 gauge to 24 it's a telecommunications way of connecting telephone lines ... I do believe Home Depot will have them or your local hardware store they are filled with jelly so you won't have to worry about corrosion either hope that helps
_________________ 16x42 Charles Leonard ... Sold 18x46 Gator Tail w/ 35 gtr stage 1 by hoyt
Fri Dec 27, 2013 11:24 pm |
diddyduck
Joined: Mon Sep 02, 2013 10:24 pm Posts: 2624 Location: ponchatoula, la
Fri Dec 27, 2013 11:26 pm |
lunacris
Joined: Thu Mar 29, 2012 8:31 pm Posts: 3251 Location: Da Parish
x2 on solder
i went from pbc connectors to solder b/c the pbc wasn't always getting a good connection.
_________________ GatorHide - MB
Fri Dec 27, 2013 11:31 pm |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
_________________ 23 swomp/ 1542 tracker
Sat Dec 28, 2013 1:37 pm |
