18X54 Dual Rig https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=50663 |
Author: | The Hairy Coot [ Fri Feb 21, 2014 11:53 am ] |
Post subject: | 18X54 Dual Rig |
Anyone hear ever run a dual engine rig on an 18x54? |
Author: | quackconsumer [ Fri Feb 21, 2014 12:10 pm ] |
Post subject: | Re: 18X54 Dual Rig |
Does trolling motor count? |
Author: | brycecheramie [ Fri Feb 21, 2014 12:57 pm ] |
Author: | Gameover [ Fri Feb 21, 2014 1:12 pm ] |
Author: | lastchance [ Fri Feb 21, 2014 1:31 pm ] |
If I remember correctly Brinkleydog ran one... |
Author: | lastchance [ Fri Feb 21, 2014 1:33 pm ] |
Nevermind it was a 20x54.... viewtopic.php?t=10153 |
Author: | diddyduck [ Fri Feb 21, 2014 1:44 pm ] |
Author: | brycecheramie [ Fri Feb 21, 2014 2:06 pm ] |
Author: | eljefe [ Fri Feb 21, 2014 7:11 pm ] |
Wider is better... If motors are too close to sides you will get dirty water.... Sent from my SCH-I545 using Tapatalk |
Author: | The Hairy Coot [ Fri Feb 21, 2014 7:33 pm ] |
Author: | msm8281 [ Fri Feb 21, 2014 9:02 pm ] |
Author: | nasty [ Fri Feb 21, 2014 9:14 pm ] |
They'll rob water from each other... Won't run very well. |
Author: | Woodiebuster [ Fri Feb 21, 2014 9:15 pm ] |
I think uncle J's dual rig was a 19x54 It sank. |
Author: | msm8281 [ Fri Feb 21, 2014 9:16 pm ] |
Author: | WhoDat88 [ Fri Feb 21, 2014 10:01 pm ] |
One motor would push that boat good. Might want to go bigger. |
Author: | rob_E [ Fri Feb 21, 2014 10:24 pm ] |
I have an 18x54 and my stage 1 motor is plenty I run 32-33 light and 26-28 loaded |
Author: | BradS [ Fri Feb 21, 2014 10:33 pm ] |
PD does pretty good on a 54... GT has to have a 60 from what I understand |
Author: | WhoDat88 [ Fri Feb 21, 2014 10:34 pm ] |
Author: | eljefe [ Sat Feb 22, 2014 9:50 am ] |
Dirty water meaning turbulent water from the corners.... Sent from my SCH-I545 using Tapatalk |
Author: | eljefe [ Sat Feb 22, 2014 9:52 am ] |
Is there a way to do them counter rotation? Sent from my SCH-I545 using Tapatalk |
Author: | calphil [ Sat Feb 22, 2014 10:52 am ] |
^^^ that would be the ticket for duals |
Author: | The Hairy Coot [ Sat Feb 22, 2014 5:49 pm ] |
Author: | Woodiebuster [ Sat Feb 22, 2014 9:09 pm ] |
That wouldn't do it, the drive shaft would have to spin the other direction. Like through a gear box or something. With outboards one motor would be in forward and the other in reverse same gear reduction with counter rotation props. Cant really do that with any of the MM's available..... cept maybe a sport v-h motor seein as they have outboard L/U's...... ![]() |
Author: | cr244 [ Sun Feb 23, 2014 8:03 am ] |
Author: | nasty [ Wed Mar 05, 2014 8:38 am ] |
Author: | Woodiebuster [ Wed Mar 05, 2014 11:06 am ] |
A gtr has a bigger gear reduction in reverse, so that wouldn't work |
Author: | Will [ Wed Mar 05, 2014 11:35 am ] |
Have the flywheel broached, change the timing, custom cam, some head work a little starter modification and run the left motor backwards... |
