Gator gliding my boat https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=50701 |
Page 1 of 2 |
Author: | gfowel [ Sat Feb 22, 2014 5:56 pm ] |
Post subject: | Gator gliding my boat |
Sanded with 100 grit. |
Author: | DmaxHunter [ Sat Feb 22, 2014 5:59 pm ] |
Post subject: | Re: Gator gliding my boat |
Looks like the skeg is getting a treatment aswell, Sent from my shitty cell |
Author: | gfowel [ Sat Feb 22, 2014 5:59 pm ] |
First coat of base. Looks blue on pic but its green. |
Author: | gfowel [ Sat Feb 22, 2014 6:11 pm ] |
Author: | gfowel [ Sat Feb 22, 2014 6:14 pm ] |
After fourth coat of base. |
Author: | txbackwater [ Sat Feb 22, 2014 8:46 pm ] |
That's great stuff...ran it on my airboat prior to getting poly, and I really liked it. Sent from my iPhone using Tapatalk |
Author: | msm8281 [ Sat Feb 22, 2014 8:51 pm ] |
The olny boat I see is that sweet ass ride in the back ground. |
Author: | krogers [ Sat Feb 22, 2014 10:16 pm ] |
Pathfinder moving on up! I check for "from the showroom floor" threads on my other favorite forum!! Good looking GG job, it's nice having the rite tools for the job. |
Author: | Team Schmo [ Sun Feb 23, 2014 7:46 am ] |
Looking good... I have two months yet till the weather moderates then I will be able to apply GG to my boat.. |
Author: | gfowel [ Sun Feb 23, 2014 9:33 am ] |
Thanks guys! Going to let it cure a couple of days. I'll start the G2 next Saturday. |
Author: | Frog [ Sun Feb 23, 2014 12:00 pm ] |
Looking good gfowel!!! I like that you did the skeg and lower end on the motor also. I just bought a 1750 GatorTrax with 35 MB and I'm cleaning it up now the start the GatorBase then G2. should be ready in a week or two. |
Author: | Kja0792 [ Sun Feb 23, 2014 8:45 pm ] |
Wanting to do the bottom of mine 19 X 54 how much and what kind should I get |
Author: | Frog [ Mon Feb 24, 2014 5:36 am ] |
http://shop.gatorglide.com/GatorBase-pl ... G2-GB2.htm ^^ this one will get you done! |
Author: | Kja0792 [ Mon Feb 24, 2014 5:44 am ] |
Does it come in colors I was wanting black |
Author: | gfowel [ Mon Feb 24, 2014 5:57 am ] |
Author: | AirFido [ Mon Feb 24, 2014 6:27 am ] |
Do you have to use the base? I have a frog spit bottom that has some wear and was thinking G4 over the top. What do you think Frog? |
Author: | Frog [ Mon Feb 24, 2014 11:41 am ] |
If you have the FS on the bottom the base will not do you any good. The GatorGlide will stick to the FS, just sand and wipe well with acetone first. |
Author: | JIMMY W [ Mon Feb 24, 2014 11:54 am ] |
Author: | JIMMY W [ Mon Feb 24, 2014 11:55 am ] |
I still have not received my GatorGlide kit!!! |
Author: | Bigrich [ Mon Feb 24, 2014 11:57 am ] |
Author: | JIMMY W [ Mon Feb 24, 2014 12:00 pm ] |
I mean Frog ![]() |
Author: | Bigrich [ Mon Feb 24, 2014 12:01 pm ] |
Author: | BlueShamu [ Mon Feb 24, 2014 12:49 pm ] |
Jimmy is collecting leftovers from everybody else's GG applications. Once he gets enough to make up a half gallon, he is going to mix them all together to get a rainbow GatorGlide application. ![]() Sent using Morse Code from my not so smart phone. |
Author: | Frog [ Mon Feb 24, 2014 1:26 pm ] |
Author: | Bigrich [ Mon Feb 24, 2014 1:50 pm ] |
Author: | JIMMY W [ Mon Feb 24, 2014 3:53 pm ] |
Author: | gfowel [ Mon Feb 24, 2014 4:16 pm ] |
Author: | msm8281 [ Mon Feb 24, 2014 7:57 pm ] |
He still has that stainless steel mystery object that needs a coating:lol: |
Author: | AirFido [ Mon Feb 24, 2014 9:34 pm ] |
Author: | gfowel [ Sat Mar 01, 2014 8:20 pm ] |
My boat sat for a week before I could apply the G2. I talked to frog and he suggested 300 grit since I was going to use a DA. I could only find 400 or 220 grit DA. So I hand sanded the side and edge with 220. Then I turned the DA down and sanded the bottom with 220 also. I used light pressure as not to take off to much material. My phone was dead so was only able to get pics after I was done. Four coats of G2 and one really light 5th on the running surface. |
Author: | Frog [ Wed Mar 12, 2014 5:13 pm ] |
Have you run the boat yet? How do you you like it? |
Author: | gfowel [ Wed Mar 12, 2014 5:58 pm ] |
NO not yet. Got my heads sent out for some improvements. ![]() |
Author: | krogers [ Wed Mar 12, 2014 7:02 pm ] |
Author: | gfowel [ Wed Mar 12, 2014 7:28 pm ] |
Author: | krazo [ Mon Mar 17, 2014 7:11 pm ] |
What color Is the final coat? I thought about going with a red base and olive green finish. Is this olive green? |
Author: | gfowel [ Mon Mar 17, 2014 7:20 pm ] |
Author: | krazo [ Mon Mar 17, 2014 7:26 pm ] |
Will you be able to tell the difference between the base coat and the finish coat? Did the base coat stay bright green when dry? |
Author: | gfowel [ Mon Mar 17, 2014 7:31 pm ] |
Author: | krazo [ Mon Mar 17, 2014 7:33 pm ] |
What do you think about using a red base? |
Page 1 of 2 | All times are UTC - 6 hours |
