boat weight
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=51203
Author:  fishingandwishing [ Fri Mar 07, 2014 12:18 pm ]
Post subject:  boat weight
About how much does an extreme gator tail hull weigh 17x54
Author:  TShriver [ Fri Mar 07, 2014 1:39 pm ]
Post subject:  Re: boat weight
559
Author:  fishingandwishing [ Fri Mar 07, 2014 4:22 pm ]
Thanks I assume that's without motor
Author:  fowllife08 [ Fri Mar 07, 2014 4:24 pm ]
Why u wanna know that?
Author:  Russ [ Fri Mar 07, 2014 7:04 pm ]
I can't and won't try to answer for him, but I always like to know myself. It's easy to calculate how much lift you can get based on bottom length and width. You also can know how much weight you're trying to carry. The wildcard are the different boats' weights. With boat weight, you can calculate draft when stationary. You then have a pretty good idea what kind of lift you need to create (with thrust/power/whatever term you wanna use and bottom surface area) to as efficiently or effectively as possible carry the load to your satisfaction.
Author:  fishingandwishing [ Fri Mar 07, 2014 10:10 pm ]
Just curious.
