Cat walks https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=51363 |
Page 1 of 2 |
Author: | BayouBuster [ Wed Mar 12, 2014 6:55 am ] |
Post subject: | Cat walks |
Wanting to put 4" cat walks on my 1754 extreme. I've only personally seen one boat with catwalks and didn't pay too much attention to them. What I'm wondering is roughly how far apart are yall putting the relief cuts? I understand that the more curve the boat has that they will need to be closer together or a wider cut. Just trying to save some time on trial and error. Thanks in advance. Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | Gigafowl [ Wed Mar 12, 2014 7:08 am ] |
Post subject: | Re: Cat walks |
You can get 6" to 8" catwalk and not give up any floor space just have them mimic your inside floor and use the space that the side flare occupies at the beam.... Did mine that way and wider catwalks are nice to sit on when hunting or fishing too.... |
Author: | BayouBuster [ Wed Mar 12, 2014 7:44 am ] |
If I use 4" angle the catwalk will be 6" total with the gunnel cap, that was my intentions. Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | fowllife08 [ Wed Mar 12, 2014 8:03 am ] |
Make sure you bevel before you weld them. I didnt and it crached the whole length of the boat over the build process. And stitxh it underneath. |
Author: | OwenDickeson [ Wed Mar 12, 2014 8:18 am ] |
Are you planning on trying to walk on them, or adding for strength? Sent from my XT1080 using Tapatalk |
Author: | mizzippi jb [ Wed Mar 12, 2014 9:05 am ] |
Author: | dfou [ Wed Mar 12, 2014 9:25 am ] |
Author: | BayouBuster [ Wed Mar 12, 2014 9:42 am ] |
Just adding them for strength, my fat ass don't need to be walking down the side of a boat lol Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | OwenDickeson [ Wed Mar 12, 2014 9:48 am ] |
I have 3" on mine, plus the gunnel cap, and I like the size of them. |
Author: | baron von [ Wed Mar 12, 2014 9:49 am ] |
what are you guys calling "cat walks" please post a pic for us un-educated folks up here - please |
Author: | OwenDickeson [ Wed Mar 12, 2014 9:52 am ] |
Author: | baron von [ Wed Mar 12, 2014 10:28 am ] |
Author: | nasty [ Wed Mar 12, 2014 10:29 am ] |
Author: | BayouBuster [ Wed Mar 12, 2014 6:29 pm ] |
Author: | 50fps [ Thu Mar 13, 2014 1:52 pm ] |
Why do the relief cut method? Just get material wide enough so you can cut the curve in. |
Author: | North LA Hunter [ Thu Mar 13, 2014 2:04 pm ] |
Author: | nasty [ Thu Mar 13, 2014 5:39 pm ] |
Author: | OwenDickeson [ Thu Mar 13, 2014 6:19 pm ] |
That's not what he is talking about doing. But its too much waste IMO. Sent from my XT1080 using Tapatalk |
Author: | OwenDickeson [ Thu Mar 13, 2014 6:21 pm ] |
Author: | nasty [ Thu Mar 13, 2014 6:43 pm ] |
Author: | BayouBuster [ Fri Mar 14, 2014 6:01 am ] |
Running the angle angle the too of the boat even with the gunnel. I want it to match the curve of the boat because it just looks goofy to me to be straight. I ordered the material yesterday, 4x2 angle, so when I get it finished I'll let y'all know how it turned out. Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | 50fps [ Fri Mar 14, 2014 9:29 am ] |
Author: | nasty [ Fri Mar 14, 2014 8:30 pm ] |
Author: | BayouBuster [ Fri Mar 28, 2014 7:21 pm ] |
Well got the catwalks finished up today. Not a bad job, went a lot easier than I thought just a ton of grinding! Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | missile [ Fri Mar 28, 2014 7:54 pm ] |
Looks good |
Author: | Bigrich [ Sat Mar 29, 2014 1:15 am ] |
Looks good justin!!!! You weld them on at a car wash??? ![]() |
Author: | BayouBuster [ Sat Mar 29, 2014 10:10 am ] |
You know it! Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | OwenDickeson [ Sat Mar 29, 2014 10:21 am ] |
Did you grind down all the welds for the relief cuts? Sent from my XT1080 using Tapatalk |
Author: | BayouBuster [ Sat Mar 29, 2014 11:58 am ] |
Yes. Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | OwenDickeson [ Sat Mar 29, 2014 12:43 pm ] |
Wonder how they will crack being ground down. Brother barely hits his with the grinder to smooth down the top a little. Sent from my XT1080 using Tapatalk |
Author: | Joe Guide [ Sat Mar 29, 2014 2:05 pm ] |
I got 14" cat walks on my 2011 "19.9 x 69" D 3 Marsh Master boat". I certain do use them when walking up from the rear to the front of the boat. |
Author: | BayouBuster [ Sat Mar 29, 2014 2:22 pm ] |
Welded 100%, shouldn't crack. Took it down some rough as roads and hit plenty of stuff on the lake today with no problems. Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | med [ Sat Mar 29, 2014 3:16 pm ] |
Author: | Bigrich [ Sat Mar 29, 2014 3:43 pm ] |
Author: | cb5331 [ Sat Mar 29, 2014 3:53 pm ] |
Mine are ground down and haven't had any issues either. Pretty sure phillip's boat is ground down too. I don't remember seeing a weld every so often on his. |
Author: | OwenDickeson [ Sat Mar 29, 2014 4:19 pm ] |
Meant to say I wonder if they will crack... I have seen some cracked that were ground down, but maybe he didn't weld it correctly. Sent from my XT1080 using Tapatalk |
Author: | Bigrich [ Sat Mar 29, 2014 6:03 pm ] |
Author: | dfou [ Sat Mar 29, 2014 6:44 pm ] |
Author: | BayouBuster [ Sat Mar 29, 2014 7:17 pm ] |
This was the first set I've done and I think they went well. Definitely not as bad as I thought it would be. I'm undecided if I want to build a little console to relocate my switch panel. Sent from my SAMSUNG-SGH-I537 using Tapatalk |
Author: | nasty [ Sun Mar 30, 2014 8:54 pm ] |
Page 1 of 2 | All times are UTC - 6 hours |
