Chines
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=51455
Author:  North LA Hunter [ Fri Mar 14, 2014 10:16 am ]
Post subject:  Chines
I've only built square chine boats and never played with double or triple tapers before. What is a double taper? A bottom that has 2 brakes in it? What is a triple? A bottom that has 3 brakes?
What is this one?
Sent from my beeper
Author:  dguidry [ Fri Mar 14, 2014 10:24 am ]
Post subject:  Re: Chines
That was someone attempting to build a round chine, but who said to hell with it.
Author:  calphil [ Fri Mar 14, 2014 10:25 am ]
Looks like my double taper .. Drafts a little deeper and doesn't slide in turns as bad ... Kinda similar to driving an extreme hull
Author:  North LA Hunter [ Fri Mar 14, 2014 10:34 am ]
Author:  OwenDickeson [ Fri Mar 14, 2014 10:46 am ]
PD just calls it a tapered chine. IDK if that would be considered a double, or a triple.
Author:  bayouboy [ Fri Mar 14, 2014 10:48 am ]
Author:  dfou [ Fri Mar 14, 2014 11:34 am ]
Author:  d_white [ Fri Mar 14, 2014 12:20 pm ]
That's a double taper. Triple taper will have one more break and be closer to "round". Here's a single taper
Author:  nasty [ Fri Mar 14, 2014 7:44 pm ]
Technically a square chine is a single taper... but most dont refer to it as such. The one you have pictured is a trippple... count the changes in angle not including performance crimps...
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Author:  dfou [ Fri Mar 14, 2014 7:45 pm ]
Author:  nasty [ Fri Mar 14, 2014 7:52 pm ]
Author:  dfou [ Fri Mar 14, 2014 8:51 pm ]
Author:  WhoDat88 [ Fri Mar 14, 2014 9:35 pm ]
Which ones you prefer?
Author:  dfou [ Fri Mar 14, 2014 9:53 pm ]
Who
Author:  Bigrich [ Fri Mar 14, 2014 10:58 pm ]
Double taper, I know turns good
Author:  Bruce Lee [ Sat Mar 15, 2014 12:47 am ]
Author:  Woodiebuster [ Sun Mar 16, 2014 9:00 pm ]
If you are running a narrow boat, you can get away with square chines. My 42" bottom doesn't slide.
A wide boat will turn a lot harder than a narrow one. If I went anything over 48" I'd have a taper chine.
Author:  willett [ Wed Mar 19, 2014 4:37 pm ]
The boat in pic and PD have always used a Double Taper or Square
Square is not a single taper whoever said that, Square is straight side to bottom
Author:  WhoDat88 [ Wed Mar 19, 2014 4:48 pm ]
I like tapered chines the best. However, square chines draft better for shallow water than any of them. I like tapered because they turn a little better.
Author:  North LA Hunter [ Wed Mar 19, 2014 5:38 pm ]
Author:  WhoDat88 [ Wed Mar 19, 2014 5:42 pm ]
Author:  willett [ Wed Mar 19, 2014 5:52 pm ]
Author:  eljefe [ Wed Mar 19, 2014 5:53 pm ]
All chines slide in the skinny stuff.... for deeper water that is true but the narrower you go with a square chine the less it slides.... my 1840 will turn on a dime in the deeper water.....unless all your weight is on the high side in a turn, you will take the boat off edge and slide.
you drink the kool aid, id rather drink the whiskey and raise hell!!!!
Author:  dfou [ Wed Mar 19, 2014 5:54 pm ]
Author:  WhoDat88 [ Wed Mar 19, 2014 6:03 pm ]
Author:  North LA Hunter [ Wed Mar 19, 2014 6:07 pm ]
I've never had a problem out of a square chine but I just felt like experimenting and trying it out. Might go with a double then go from there.
Sent from my beeper
Author:  WhoDat88 [ Wed Mar 19, 2014 6:11 pm ]
[quote="North LA Hunter"]I've never had a problem out of a square chine but I just felt like experimenting and trying it out. Might go with a double then go from there.
Sent from my beeper[/
I am interested to know how the double performs
Author:  willett [ Wed Mar 19, 2014 7:52 pm ]
Author:  WhoDat88 [ Wed Mar 19, 2014 8:48 pm ]
That very well may be the case.
Author:  Ducaholic [ Thu Mar 20, 2014 8:15 am ]
Excel and Prodigy Boats are triple chine.
Author:  WhoDat88 [ Thu Mar 20, 2014 8:33 am ]
Author:  Ducaholic [ Thu Mar 20, 2014 11:08 am ]
Author:  cb5331 [ Thu Mar 20, 2014 11:11 am ]
Triple handles well, but they aren't usually broke as far forward and the break isn't usually as severe a true round so they don't draft as much water, imo. I like the compromise.
