First Boat on a budget - Need advice and recommendations https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=51465 |
Author: | ehill [ Fri Mar 14, 2014 8:25 pm ] |
Post subject: | First Boat on a budget - Need advice and recommendations |
I've decided I'm going to get/build my first boat Here is what I'm thinking: Boat: Basic Jon Boat (aluminum, riveted, probably used) Length: 12' or 14' Width: 32" or 36" Motor: 13hp Predator from Harbor Freight or 16hp Duromax from Maxtools Drivline: surface drive, longtail or shorttail Use: Fishing and Duck Hunting (mostly deep water, but occasionally gravel riverbed) Passengers: 2 adults, chocolate lab & gear. Occasionally 3 adults Budget: $2,000 (stop laughing) I'd like to get opinions on which drive type to use based on how the boat will be used. I am planning on building the driveline myself, but have also looked at some of the longtail kits (sps, mud-skipper, etc...). Given the fact that I'm not trying to plow through a bunch of mud, just the occasional low spot in the river which has a gravel bed, how would you build this boat on a budget? I would love to have a real duck boat (go-devil, mud-buddy, xpress, etc...) with a big v-twin on the back, but at this point, I'd like to cut my teeth on a cheap boat and upgrade in a few years. Thanks for any advise. -Erik |
Author: | msm8281 [ Fri Mar 14, 2014 9:11 pm ] |
Post subject: | Re: First Boat on a budget - Need advice and recommendations |
Go 14x36 if that's your only choices |
Author: | ehill [ Fri Mar 14, 2014 11:07 pm ] |
36" just seems to be the most common in my neck of the woods. I'd love to go wider, but I don't think I can source anything locally over 36" wide for cheap. |
Author: | fowllife08 [ Sat Mar 15, 2014 6:13 am ] |
Just my opinion, save ur money and get what you really want down the road. 2,000 isnt gonna go as far as you think. |
Author: | dillakilla12 [ Sat Mar 15, 2014 6:35 am ] |
I would get the mud skipper kit from backwater if I were you, save up for a couple more months and get ya a used jon and roll out. Gonna be a little over budget though Sent from my SM-N900V using Tapatalk |
Author: | nasty [ Sat Mar 15, 2014 6:56 am ] |
Might try to get one of the larger sneak boats that pop up in the classifieds every once in a while they usually sell for around 2k Sent from my SAMSUNG-SGH-I337 using Tapatalk |
Author: | USCG4X4 [ Sat Mar 15, 2014 12:02 pm ] |
Go to a 14 ft minimum. I started with a 12 and quickly went to a 14. I have about 6-7k in mine with a surface drive and a bunch of other goodies. It was a new boat and motor though. Sent from my iPhone using Tapatalk |
Author: | flatontheplatte [ Sun Mar 16, 2014 1:30 pm ] |
Seems doable. I would look for a 16', should be able to find a used one for cheap. I'm sure there are plenty of older GDLT that can be had for a grand or less. Might take a little looking but I bet you can find what you need. |
Author: | ehill [ Sun Mar 16, 2014 6:04 pm ] |
I think I've decided to go with at least a 14' jon boat. Based on my use described in the original post, what type of lower unit should I build, Surface Drive, Longtail, Shorttail? Thanks, -E |
Author: | mud slinger 69 [ Sun Mar 16, 2014 6:26 pm ] |
14-36 with a 16hp longtail for your buget. not going to be a speed boat but beats walking. |
