Removing paint with pressure washer
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=51574
Author:  jarnotski [ Tue Mar 18, 2014 7:28 pm ]
Post subject:  Removing paint with pressure washer
I just bought a 1448 and want to redo the paint. The factory paint is ok but the previous owner must have added another coat of something and it is chipping in spots (and it's white). I don't want to sped my whole summer sanding to remove the paint and I'd like to stay away from using a chemical stripper. Anyone ever had luck with a pressure washer. The biggest rental I can get is a 4,000 PSI.
Thanks for advice,
Author:  Frog [ Wed Mar 19, 2014 4:36 am ]
Post subject:  Re: Removing paint with pressure washer
It probably not going to work for you. You 'll be better off sanding or wire wheel. Save the rental money for eye protection and beer you'll need them both.
Author:  kibb [ Wed Mar 19, 2014 6:24 am ]
I think some do chemical stripper and pressure washer.
Author:  gaddie1093 [ Wed Mar 19, 2014 7:25 am ]
Hood Magic will take the paint right off
Author:  DeltaRunner [ Wed Mar 19, 2014 9:23 am ]
I tried pressure washing. Didn't do shit. Sanded my whole boat down (inside and out and bottom) in 6-8 hours. Angle grinder with a 60 grit flapper wheel.
Author:  Kja0792 [ Wed Mar 19, 2014 9:38 am ]
I have an attachment for my pressure washer that draws sand into the nozzle if u can find one u can do the whole boat in to hours but do it in a low spot in your yard because you will have sand everywhere
Author:  pearl river outlaw [ Wed Mar 19, 2014 9:59 am ]
Get you a couple gallons of KS3 and take a brush and spread it on and let it set....Then wash it off with a pressure washer. You may half to go back over in a few places that you didn't get good with the stripper but that stuff is the CHIT!
Author:  DeltaRunner [ Wed Mar 19, 2014 10:32 am ]
Even if you are sucessful getting the paint off with stripper, you will still have to sand the bare aluminum hull before you paint or it won't stick.
Author:  pearl river outlaw [ Wed Mar 19, 2014 10:33 am ]
Author:  DeltaRunner [ Wed Mar 19, 2014 11:07 am ]
Author:  pearl river outlaw [ Wed Mar 19, 2014 12:15 pm ]
Author:  DeltaRunner [ Wed Mar 19, 2014 1:04 pm ]
Author:  txkingfisher [ Wed Mar 19, 2014 3:27 pm ]
You can get a grit eductor that hooks to a pressure washer from harbor freight or northern tool or any place like that. It takes a decent sized pressure washer to make it work really good, but it's an easy way to remove paint.
