It is currently Tue Jul 15, 2025 9:04 am
Reply to topic  [ 13 posts ]
 boat build help
Post boat build help
I have a pretty good idea drawn up to build a hull my self. I work for a hvac contractor and am able to get all of the material at cost. the only thing im not sure about is how to bend hte square tubing for the stringers to give the boat that roll to the nose. Im planning on using 1-1/2" by probably 3/4" square tubing. if anyone has any suggestions or could help me out on this that would be great.
Fri Mar 21, 2014 8:25 am
Post Re: boat build help
You can cut slits, or get you a roller from harbor freight.
35 GTR chasin a BBC 1848
Fri Mar 21, 2014 8:29 am
what about going with 1-1/2" sch 40 aluminum pipe as stringers? any idea if that would be better than 1-1/2 x 3/4 square
Fri Mar 21, 2014 9:03 am
dis regard the pipe question i just thought of how difficult that would be to weld. does 1-1/2" x 3/4" square sound like the right material for the stringers?
Fri Mar 21, 2014 9:10 am
Fri Mar 21, 2014 9:30 am
Fri Mar 21, 2014 9:39 am
I used the back tire on my tractor when I made all my hoop nets. You can use just about anything to bend it just take it slow and don't be in a rush.
Fri Mar 21, 2014 9:44 am
I've also seen uncle J hulls where the longitudinal stringers stopped where the rake began. and from the rake to the nose he ran stringers horizontally (left to right). Not the best, but it could work
[Stage 2.5]
Fri Mar 21, 2014 9:47 am
Or a split tree or good fork in a tree
Fri Mar 21, 2014 9:53 am
Plate rolls are the best thing. I weld my braces together and roll all of them at the same time.
Sent from my beeper
Fri Mar 21, 2014 10:01 am
Before i got a roller i used the "V" in my utility trailer to bend em.
Fri Mar 21, 2014 10:49 am
http://m.harborfreight.com/tubing-rolle ... 20provided
Swagoffroad.com
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Sat Mar 22, 2014 10:23 am
I used a tubing roller. Rolled my hat section in it. Took about 20 min to roll all of mine.
Sun Mar 23, 2014 9:57 am
Users browsing this forum: No registered users and 85 guests
