Pod Performance https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=51925 |
Author: | drpwells [ Sun Mar 30, 2014 8:39 pm ] |
Post subject: | Pod Performance |
I recently bought a 1748 southfork w/GT 35. The boat has rear pods attached. I'm not getting the performance I'd like. Just wondering if cutting them off will help significantly?? I know this has always been a beat down topic but I'm asking for some input people have experienced. I hate to cut them off then the boat not perform any better. I run mostly deep water and I just cant get the boat to the speeds I was hoping for. Thanks |
Author: | duckduckboom [ Sun Mar 30, 2014 8:45 pm ] |
Post subject: | Re: Pod Performance |
Cut em. |
Author: | mud slinger 69 [ Mon Mar 31, 2014 6:01 am ] |
I've cut them off 2 of my boats. What speeds are you getting,Whats in the boat, Motor mods? Need more Info. |
Author: | drpwells [ Mon Mar 31, 2014 6:21 am ] |
In the boat is 1 battery, 6 gallons of gas and life jackets ect. Speeds by myself in deep water is 22-23. No mods on motor. New prop. |
Author: | dillakilla12 [ Mon Mar 31, 2014 5:13 pm ] |
Cut em Sent from my SM-N900V using Tapatalk |
Author: | Gigafowl [ Mon Mar 31, 2014 7:00 pm ] |
Author: | drpwells [ Mon Mar 31, 2014 9:37 pm ] |
I'll try to get some pics. |
Author: | drpwells [ Mon Mar 31, 2014 9:41 pm ] |
Mod v front but completely flat with no hooks or dents. |
Author: | eljefe [ Mon Mar 31, 2014 9:43 pm ] |
A 1748 should not need pods to run flat with a 35. you drink the kool aid, id rather drink the whiskey and raise hell!!!! |
Author: | eljefe [ Mon Mar 31, 2014 9:44 pm ] |
Where is your gas tank and battery? you drink the kool aid, id rather drink the whiskey and raise hell!!!! |
Author: | Gigafowl [ Mon Mar 31, 2014 9:54 pm ] |
Have you check - out of water max rpms - to see if it will turn 4100 rpm ??? Pods don't look too bad all in all they are well made. |
Author: | drpwells [ Tue Apr 01, 2014 6:30 am ] |
The out of water rpms are 4100+ but in water I struggle to get 3600. I did notice my transom is 17" and saw where short GT needs 16. This should throw me off that much would it?? My tank and battery are in the back. |
Author: | msm8281 [ Tue Apr 01, 2014 6:33 am ] |
Move gas to front. |
Author: | eljefe [ Tue Apr 01, 2014 6:41 am ] |
Move gas to front. Surface drives run best flat. If all the weights in the back it won't get flat. Probably why the pods are their. And yes 1" on transom height can make a difference. It's changes the angle of the drive...... you drink the kool aid, id rather drink the whiskey and raise hell!!!! |
Author: | Gigafowl [ Tue Apr 01, 2014 6:58 am ] |
I agree with Eljefe - did I just type that - LOL Also try changing the motor pin to the other holes... Also put a second person way up front to see if there is an improvement - or take a big ice chest and put water in it for ballast.... |
Author: | txkingfisher [ Tue Apr 01, 2014 10:12 am ] |
How much of the prop is out of the water at 3600rpm? |
Author: | drpwells [ Tue Apr 01, 2014 11:02 am ] |
I'd say roughly half. Since my transom is 17 I did move to bottom hole. Perhaps I should try top hole. I notice after moving from middle to bottom I seem to run out of upward trim. The trim is maxed out. I put a large 300 lb guy in the front but never gained anything as expected due to weight. The mph was close to same but max rpms were 3300. |
Author: | calphil [ Tue Apr 01, 2014 11:58 am ] |
Go to top pin .. Should help |
Author: | JD [ Fri Apr 04, 2014 4:16 pm ] |
You may be over proped. What prop are you running, you may try a smaller top pulley if i the boat does't have any hooks, and prop is new and a gt recommend prop. Check engine health before removing the pods. A compression test should have both sides about the same. A leak down test is a better test if you know how.. I have a buddy that weights about 350 and had a light 17x48 that ran like shit until he put pods on, I am not going to post his speed , most here would not believe them if I did. If the pods are creating lift and not drag they are not the problem. Checking with a straight edge the pods should flow just like the bottom of the boat ,or just be a little higher, is the bow plowing. JD |
