What paint rollers to use?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=52209
Author:  Livetodrive [ Wed Apr 09, 2014 11:08 am ]
Post subject:  What paint rollers to use?
I'm about to paint my alweld with Duralux aluminum boat green. I understand the prep and process of doing this. Everyone says to roll it because the product won't spray. What kind of and size rollers do I need? I brush the nick and crannies and strakes? Thanks
Author:  baron von [ Wed Apr 09, 2014 3:17 pm ]
Post subject:  Re: What paint rollers to use?
a 6" inch X 3/8" to 1/2" nap roller the white ones with the yellow stripe running through it, get at Home depot
Author:  kibb [ Wed Apr 09, 2014 4:04 pm ]
Spray it with a wash down gun then have someone roll it while it's still wet. Painted many hard to get spots on drilling rigs that way.
Author:  kibb [ Wed Apr 09, 2014 4:08 pm ]
Listed as siphon spray blow gun
Author:  jp1854 [ Wed Apr 09, 2014 8:44 pm ]
I used wooster 4" roller 3/16" nap because it leaves a smoother finish
Author:  poke_chop666 [ Wed Apr 09, 2014 9:40 pm ]
So u can't thin that paint down and spray it? I was thinking about doing mine but was going to spray it. Btw how much ain't do you use for a 1642 flat?
Author:  forever draggin [ Wed Apr 09, 2014 9:44 pm ]
Author:  AKA Freshwaterkilla [ Wed Apr 09, 2014 9:58 pm ]
I've seen it sprayed a bunch of times
Sent from my iPhone using
Author:  dfou [ Wed Apr 09, 2014 10:04 pm ]
Try not to thin it much. The finish won't be as durable if you use too much thinner
Author:  poke_chop666 [ Wed Apr 09, 2014 10:16 pm ]
Oh, I thought you couldn't thin it from this post...how far does the paint go? 1/2 gallon or what for a 16 foot boat?
Author:  DeltaRunner [ Thu Apr 10, 2014 12:15 am ]
I don't know about Duralux, but I used Pettit Shipendeck to paint my boat. Sprayed 3 coats on the inside and the outside. Used 3 quarts. However, I did not paint the floors or the front deck.
Like dfou said, the Duralux will not be as durable if thinned. The Pettit sprayed pretty easy without thinning. Plus you get a better finish by spraying IMO.
Author:  mud slinger 69 [ Thu Apr 10, 2014 5:42 am ]
Any roller will work 1/4" nap will give ya a smoother finish thou.
Author:  duckduckboom [ Thu Apr 10, 2014 6:35 am ]
its a mud boat who cares. put sand in it while its wet, paint over it again
Author:  renovator [ Fri Apr 11, 2014 4:41 am ]
Buy a hvlp gun with a 2.5mm tip. U won't have to thin it much. About 50 bucks on the web
