New rig https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=52261 |
Page 1 of 2 |
Author: | Buzz Killington [ Fri Apr 11, 2014 11:08 am ] |
Post subject: | New rig |
As much as I tried to avoid it. I got one. Found a smoking deal on a brand new boat motor combo. Having been told I am staying put and not deploying to AFG again, I got a 2006 MB with 8 hours on it, and a brand new Lowe 1760 roughneck. Yep - 8hours on the motor. Hex prop 11x10 is brand new - big blade already in the mail. boat needs to be completely rigged - lights, bilge, 12v receptacle etc... Reviews to follow once I get it kitted out. Heres a pic. |
Author: | baron von [ Fri Apr 11, 2014 11:16 am ] |
Post subject: | Re: New rig |
sweet looking rig - be sure to get some more pics up with your review - and for godsake stay out of Asscrackestan !! I had a Lund Alaskan and that thing took a beating very well, solid boats for up here that is for sure. did you mean lowes roughneck? |
Author: | Buzz Killington [ Fri Apr 11, 2014 11:30 am ] |
yep - Lowe Roughneck - edited above. |
Author: | baron von [ Fri Apr 11, 2014 1:27 pm ] |
how much ice you got on your lakes now? it's melting fast here |
Author: | Buzz Killington [ Fri Apr 11, 2014 4:10 pm ] |
3-12 " most places. Some running water is open |
Author: | brickgw [ Fri Apr 11, 2014 4:19 pm ] |
Author: | diddyduck [ Fri Apr 11, 2014 4:22 pm ] |
good deal man hope ya enjoy it..how the heck an 06 with 8 hrs??? and whats that on the skeg? |
Author: | Buzz Killington [ Fri Apr 11, 2014 4:50 pm ] |
Rock guard on the skeg 8 hours comes from 1 tank of gas through the boat in 6 years. Guy bought it in 2011 brand new - used it twice. Then he winterized it and left it in his garage. For me to find! |
Author: | Team Schmo [ Fri Apr 11, 2014 7:19 pm ] |
Great looking rig.. Congrats |
Author: | Hzepp88 [ Fri Apr 11, 2014 11:06 pm ] |
Congrats on the rig, looks great! My brother is at Ft Irwin right now, extremely thankful for your service and glad to hear your gonna be staying put for a while! |
Author: | baron von [ Sat Apr 12, 2014 8:32 am ] |
^^^ Ft Irwin - someone is ramping up for a deployment? Buzz did the motor come with the manuals so you can do the recommended service on the motor with the right stuff? |
Author: | Buzz Killington [ Sat Apr 12, 2014 1:40 pm ] |
It did. Already contacted MB and then got my compression tester out . Going to zerk the shaft eventually but for a comprehensive go over - - oil - filter -plugs - grease shaft and all zerks -check belt tension -tighten all bolts -clean carb - run new fuel through it for nlt 30 minutes to see how it runs - tighten bolts on transom - change fuel filter - prior to running - check seals- seem great - check shaft - drink a beer - prep boat for rigging. Already started drilling holes. |
Author: | Buzz Killington [ Sat Apr 12, 2014 4:17 pm ] |
viewtopic.php?t=52294 |
Author: | baron von [ Sat Apr 12, 2014 4:47 pm ] |
Your a good man Charlie Brown ![]() |
Author: | jjort [ Sat Apr 12, 2014 4:53 pm ] |
Author: | baron von [ Sat Apr 12, 2014 4:56 pm ] |
Author: | Buzz Killington [ Sun Apr 13, 2014 5:19 pm ] |
Motor is in pretty good shape. Did about 90% of what I wanted. How the heck do you loosen and tighten the bolts behind the clutch? Crows foot didnt even work. |
Author: | Russ [ Sun Apr 13, 2014 6:13 pm ] |
The crows foot worked fine (and was how I saw it done in the video I watched). Wasnt exactly easy, though |
Author: | Buzz Killington [ Sun Apr 13, 2014 7:26 pm ] |
I cant reach 2 nuts with it. |
Author: | Russ [ Sun Apr 13, 2014 7:51 pm ] |
Author: | baron von [ Sun Apr 13, 2014 7:59 pm ] |
sometimes I sacrifice a cheap wrench - heat it up and bend/cut/shape into a "special purpose" wrench - would making special purpose wrench help? |
Author: | AKA Freshwaterkilla [ Sun Apr 13, 2014 8:01 pm ] |
A short stubby combo wrench Sent from my iPhone using |
Author: | msm8281 [ Sun Apr 13, 2014 8:07 pm ] |
Author: | AKA Freshwaterkilla [ Sun Apr 13, 2014 8:19 pm ] |
Author: | Buzz Killington [ Mon Apr 14, 2014 4:00 am ] |
Author: | Buzz Killington [ Mon Apr 14, 2014 4:54 am ] |
Author: | BoatDR [ Mon Apr 14, 2014 8:40 am ] |
Author: | AKA Freshwaterkilla [ Mon Apr 14, 2014 9:41 am ] |
I admit its a pain in the ass but it can be done just keep flipping wrench over 1/8th of a turn at a time Sent from my iPhone using |
Author: | AKA Freshwaterkilla [ Mon Apr 14, 2014 10:06 am ] |
Author: | Buzz Killington [ Mon Apr 14, 2014 11:13 am ] |
Author: | BoatDR [ Mon Apr 14, 2014 11:41 am ] |
Author: | Bayoufrank [ Mon Apr 14, 2014 8:47 pm ] |
Post subject: | Sorry about that |
Sorry about that |
Author: | Bayoublackhunter [ Mon Apr 14, 2014 8:52 pm ] |
Author: | Bayoufrank [ Mon Apr 14, 2014 9:03 pm ] |
Post subject: | Re: Wrong post |
Author: | North LA Hunter [ Mon Apr 14, 2014 9:10 pm ] |
Author: | Buzz Killington [ Tue Apr 15, 2014 3:20 pm ] |
Thanks again BayouFrank. New rig back on track. |
Author: | baron von [ Tue Apr 15, 2014 3:24 pm ] |
so - all back togther and ready to break some parts? |
Author: | Buzz Killington [ Tue Apr 15, 2014 4:21 pm ] |
Author: | baron von [ Tue Apr 15, 2014 5:35 pm ] |
hang in there Buzz - keep your stick on the ice, I'm pulling for you |
Author: | Buzz Killington [ Fri Apr 18, 2014 4:06 pm ] |
The story continues, Made it out on the water today. COLD But opn water is open water. I had to be fast as an ice shelf broke from a nearby island and would be at the ramp within the hour. Put the back of the boat in the water to see if it had any issues with coils - as I've had in the past AFTER I launched. Ran it to see how it handled a bit of resistance from the water - no issues so i launched. Puttered along to get a feel for it then clamped the throttle. Wow. From a 27 PD to a 35 MB. Got on step fast. Played with the trim to find the deep water sweet spot. Got it dialed in. Ran deep for 10 minutes WOT took a corner and it happened.....sputter....prop stops.....wtf?.... Engine shut off? Gas issues? Nope.... When turning the clutch button touched my coat and disengaged the clutch....motor was still on =) could hardly hear it the wind was howling. Engage and off I run again towards the shallows. To the shallows I go. 2ft was as shallow as I could find with all the flooding we've had. Care to guess the speeds both shallow and deep? Load was me, spare tire, and deep cell. Stock prop. 2006 MB - not the BB its a 10x11. Scroll down for answers Speeds: Deep @3990/4000 rpm was 22.5mph Shallow @4000rpm was 24mph Nothing stellar I know, but for a 715lb boat I was delighted with those speeds. Because with a full hunt load and 3 guys I should be able to see 18-20mph with a BB. Which is EXACTLY what I want. I think the BB will add a bit but my motor was pinned and almost seemed like it was hitting the limiter. Although I believe the limiter is at 4300 rpm? More to follow. Thanks for reading. Happy easter guys =) |
Page 1 of 2 | All times are UTC - 6 hours |
