started painting https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=52911 |
Author: | poke_chop666 [ Fri May 02, 2014 12:10 pm ] |
Post subject: | started painting |
Started the painting process today. Looks good so far. How may coats do I need? 1 coat looks good just wanna make sure it last. It has some holidays but once I came it you won't be able to see them. |
Author: | Pete14 [ Fri May 02, 2014 12:24 pm ] |
Post subject: | Re: started painting |
I will be honest. I didn't even look at your paint job. The avatar distracts me every time. Lol |
Author: | DeltaRunner [ Fri May 02, 2014 2:07 pm ] |
Holidays? Looking good. I put three coats of base on my boat then camo. If you sprayed id say two more. If you rolled it, one more coat should be plenty. Be sure to sand and clean it between coats. |
Author: | Lucyfabre [ Sat May 03, 2014 6:14 am ] |
I sprayed two coats then camouflaged then flat clear. Held up like a champ. Sent from my bag phone. |
Author: | poke_chop666 [ Sun May 04, 2014 9:54 pm ] |
I went with one coat because I rolled it pretty heavy. Then the stencils. Not as good as I hoped but looks decent. |
Author: | GhostHunter [ Mon May 05, 2014 4:47 am ] |
Looks very good Pok Chop |
Author: | poke_chop666 [ Mon May 05, 2014 6:02 pm ] |
Thanks ghost. Here's some better pics. |
Author: | mud slinger 69 [ Mon May 05, 2014 6:07 pm ] |
Like the pattern |
Author: | DUCK HEARSE [ Mon May 05, 2014 6:34 pm ] |
Looks like somebody's Spray graffiti on it |
Author: | poke_chop666 [ Tue May 06, 2014 9:53 pm ] |
Yea that's what I said. I'm not really happy with it. I used stencils and due to the rib down the sides it don't allow them to sit flat. Therefore instead of a good clean line it's fuzzy |
Author: | fowllife08 [ Wed May 07, 2014 11:25 am ] |
I wanna be in ur avitar, alll 3 of em! |
Author: | poke_chop666 [ Fri May 09, 2014 3:57 pm ] |
You and me both |
Author: | southernfire97 [ Fri May 09, 2014 4:10 pm ] |
Just did the outside of mine. I've still got to do the inside. |
Author: | poke_chop666 [ Sat May 10, 2014 4:53 am ] |
Looks good |
Author: | mud slinger 69 [ Sat May 10, 2014 5:29 am ] |
Dam thats good looking which senticls did you use? |
Author: | mud slinger 69 [ Sat May 10, 2014 5:31 am ] |
Author: | southernfire97 [ Sat May 10, 2014 3:35 pm ] |
Styx river shadow grass stencils. Used black, tan, brown, OD green and a lighter green. Did three different passes with the grass stencil to give it some depth. |
Author: | poke_chop666 [ Sat May 10, 2014 7:36 pm ] |
This is what my stencils look like up close. Boat don't look so good though |
Author: | DuckHunterF250 [ Sat May 10, 2014 10:43 pm ] |
next time your boat on its side it will help the stencil lay more flat. take a metal coat hanger and press it on the spots its doesnt lay flat like around the crimp in the side. will make the lines crisp. |
Author: | poke_chop666 [ Sat May 10, 2014 10:55 pm ] |
I had it on its side but didn't know about the clothes hanger. I tried with my hand but just painted my fingers |
Author: | southernfire97 [ Sun May 11, 2014 6:20 am ] |
Mine has 3 stencils with it. I flipped mine over and painted it that way. |
