Battery Up Front https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=52968 |
Author: | Duckaholic-Anonymous [ Sun May 04, 2014 9:10 pm ] |
Post subject: | Battery Up Front |
For those of you running a battery under the front deck, are you using a remote terminal post in the back or are you running straight to the motor? I'm looking for a terminal I can use that looks safe and makes sense and can't find one. Let me know if any of you have something that works. Thanks! Sent from my iPhone using Tapatalk |
Author: | Ducknut [ Mon May 05, 2014 4:27 am ] |
Post subject: | Re: Battery Up Front |
Like this? http://www.genuinedealz.com/blue-sea-sy ... inch-studs I have a battery up front in my little fishing boat. Works fine, use #2 wire to the back. |
Author: | mud slinger 69 [ Mon May 05, 2014 5:43 am ] |
^^ That's what i have in mine. Works fine. Got it for a local boat shop Like 15 bucks. |
Author: | gfowel [ Mon May 05, 2014 7:14 am ] |
Also could use a single post just like the one pictured for the ground and a battery switch for the positive. |
Author: | T-Bubba [ Mon May 05, 2014 7:25 am ] |
whats your reasoning? You will have to run a larger wire to not overheat. |
Author: | Duckaholic-Anonymous [ Mon May 05, 2014 10:50 am ] |
I just want the majority of weight up front. Big cable is not a problem. I'm actually most concerned with the battery being located near the tank, but will make sure there's nothing dangerous Sent from my iPhone using Tapatalk |
Author: | WestEndAngler [ Mon May 05, 2014 11:17 am ] |
Author: | kibb [ Mon May 05, 2014 3:54 pm ] |
^this. And make sure your battery connections are tightened with a wrench. Loose connection can sometimes spark. |
Author: | Duckaholic-Anonymous [ Mon May 05, 2014 4:14 pm ] |
Do you know if I would have to run a separate cable for the ground wire all the way back as well? Or could I locally ground that remote terminal? Electricity can be perplexing sometimes. Sent from my iPhone using Tapatalk |
Author: | kibb [ Mon May 05, 2014 4:47 pm ] |
Run your hot and ground all the way to the back. |
Author: | Duckaholic-Anonymous [ Mon May 05, 2014 6:47 pm ] |
Thank you! 3 bucks a foot on an 18 foot boat won't be cheap but will be worth it for getting on plane (I have a longtail) Sent from my iPhone using Tapatalk |
Author: | krogers [ Mon May 05, 2014 8:20 pm ] |
http://www.genuinedealz.com/ If you have time, they have decent pricing on marine wire and what not. Sent from my iPhone using Tapatalk |
Author: | Duckaholic-Anonymous [ Mon May 05, 2014 9:04 pm ] |
2 gauge should be plenty, right? Sent from my iPhone using Tapatalk |
Author: | Duckaholic-Anonymous [ Mon May 05, 2014 10:26 pm ] |
This might be cheaper. Haven't checked shipping though: http://gregsmarinewiresupply.com/Zen/in ... 42c4b9c7e9 Sent from my iPhone using Tapatalk |
Author: | mud slinger 69 [ Tue May 06, 2014 5:23 am ] |
Get some thick ass 20 foot jumper cables shouldn't be more than 50 bucks |
Author: | schauv01 [ Tue May 06, 2014 5:30 am ] |
2 Ga will be more than enough. This is what I did with mine. You can find these on amazon and make hooking and unhooking accessories a breeze. Put a pair up front to hook your batteries, long cables, and accessories into it, and another pair astern to hook any other accessories (charger) and motor up. http://www.amazon.com/Blue-Sea-Systems- ... ystems+150 Sent from my iPad using Tapatalk HD |
Author: | gfowel [ Tue May 06, 2014 10:13 am ] |
www. pacerwiregroup.net has it for $2.78 a foot. |
Author: | Duckaholic-Anonymous [ Thu May 08, 2014 8:35 am ] |
Just saw 20 foot 2 gauge jumper cables at autozone for $50 Sent from my iPhone using Tapatalk |
Author: | Duckaholic-Anonymous [ Thu May 08, 2014 8:36 am ] |
That's about $1.25 a foot Sent from my iPhone using Tapatalk |
Author: | gfowel [ Thu May 08, 2014 10:12 am ] |
Author: | tylerduckman [ Sun May 11, 2014 7:49 pm ] |
Try a car stereo shop for a distribution block. |
