Best Self Etching Primer? https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=53135 |
Author: | Duckaholic-Anonymous [ Sun May 11, 2014 1:46 pm ] |
Post subject: | Best Self Etching Primer? |
I'm doing some touch up work and don't really care for the rattle can paint. Anyone have good success with a certain brand? Sent from my iPhone using Tapatalk |
Author: | Randy S [ Sun May 11, 2014 3:17 pm ] |
Post subject: | Re: Best Self Etching Primer? |
It's been a while, so there may be something better, but I've used PPG DPX171 and it worked fine. There were some limitations on what you could direct topcoat it with, so you'll want to check the datasheet. I know you want to stay away from the rattle cans, but I've used SEM self-etching in the can it worked well. |
Author: | North LA Hunter [ Sun May 11, 2014 3:50 pm ] |
For touch up I would get the Johnson/Evinrude zinc chromate primer in a spray can. Sent from my beeper |
Author: | Duckaholic-Anonymous [ Sun May 11, 2014 4:03 pm ] |
I say touch up lightly, it's touch up on the inside and I'm debating priming the bottom of the boat once I remove some old flexsteel. What do the boat manufacturers use? Sent from my iPhone using Tapatalk |
Author: | Frog [ Sun May 11, 2014 6:32 pm ] |
What are you putting on the bottom once you get the steel flex off? |
Author: | Duckaholic-Anonymous [ Sun May 11, 2014 6:45 pm ] |
More steelflex....jk gator glide Sent from my iPhone using Tapatalk |
Author: | Frog [ Sun May 11, 2014 6:57 pm ] |
