2 questions about hydroturf and short transom https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=54329 |
Author: | Kdew05 [ Thu Jun 26, 2014 10:18 am ] |
Post subject: | 2 questions about hydroturf and short transom |
Which hydroturf, pattern, color, ect. to use in boat? Can anyone tell me a pro about having a short transom?... All I can find is reasons not to have one, are there any reasons to have one or a time that it is better than a tall transom?.. (found a deal on a short transom boat) |
Author: | TonyGMcElroy [ Thu Jun 26, 2014 10:23 am ] |
Post subject: | Re: 2 questions about hydroturf and short transom |
Any color or pattern and i like short transom when trying to go under low trees or pipelines |
Author: | BKScripto [ Thu Jun 26, 2014 10:31 am ] |
Color and pattern are subjective, pick out what you want. That being said, I'll probably use Swamp Camo in the groove cut when I put my order in. I have to go under bridges a lot on the lakes I hunt, and when the water is up it can be a tight squeeze. The mud motors are already taller than a regular outboard, so I went with short shaft to give me a few extra inches of clearance. |
Author: | basinhunter2012 [ Thu Jun 26, 2014 10:37 am ] |
i went short transom because theres bridges around me i have to get under also i go in the swamp a good bit here and dont hit as many low hanging limbs |
Author: | OwenDickeson [ Thu Jun 26, 2014 10:57 am ] |
I think the molded diamond turf is the most durable. |
Author: | Frog [ Thu Jun 26, 2014 1:50 pm ] |
Author: | OwenDickeson [ Thu Jun 26, 2014 2:03 pm ] |
Author: | msm8281 [ Thu Jun 26, 2014 2:39 pm ] |
Author: | OwenDickeson [ Thu Jun 26, 2014 2:51 pm ] |
The molded will hold up better. The only molded sheet is the diamond. Sucks its only available in the smaller sheets though. |
Author: | Frog [ Thu Jun 26, 2014 3:34 pm ] |
Author: | Kdew05 [ Thu Jun 26, 2014 7:45 pm ] |
Thanks for all the input, OD if you could shoot me your info so I can figure out how many sheets of which pattern would best suit what I'm looking for if you don't mind... |
Author: | nellie [ Fri Jun 27, 2014 12:47 pm ] |
Short transom for me as well, lower profile, easier to hide, easier to navigate around and under trees and low limbs when lakes and rivers rise. Some of these motors like Gatortail really stick up like a sore thumb on a tall transom. |
