It is currently Tue Jul 08, 2025 9:27 pm
Reply to topic  [ 11 posts ]
 Minn Kota battery charger issue
Post Minn Kota battery charger issue
I bought a MK210D charger on my boat. Just plugged it in after going to the lake yesterday afternoon and it's showing that my starting battery (plug 2) is charging but it's showing a connection error with trolling battery (plug 1).
I've checked and double checked but the connection is good. Any ideas on fixing?
Has anyone had this issue with a charger before?
1748 Prodigy with MB 4500 Black Death
Sun Jul 13, 2014 4:06 pm
Post Re: Minn Kota battery charger issue
Did u splice any of the leads coming out of the charger? Fuse good?
Sun Jul 13, 2014 4:13 pm
Also I have killed my battery completely and my charger would show this. I had to charge it with another charger then it kicked in and started to charge from my on board mk210D
Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's
Boat Name: The Gar Barge
Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Sun Jul 13, 2014 4:19 pm
How old is your trolling battery? Check fuse like stated above..
You can't fix stupid
Sun Jul 13, 2014 4:23 pm
Now the question is how to check the fuse. Do I just pull the wire or does it twist off?
Please forgive my newbness
Battery is brand new and the wire hasn't been cut at all so I'm thinking fuse issue
Sun Jul 13, 2014 6:21 pm
Twist and pull the fuse holder apart.
Sun Jul 13, 2014 7:31 pm
If it is not the fuse.. Take your one that is not working and put it on the battery that is just to see if you can make it light up if it will, then it's your battery.. Only reason I say this I had the problem last year with a battery that was only 6 months old.. If the batteries are junk the charging system will not work..
Sun Jul 13, 2014 9:51 pm
just to be sure... the fuse holder is attached to the main chargin unit behind the cable that goes to the battery.
Wanna make sure i'm pulling on the right thing.
Mon Jul 14, 2014 6:25 am
Yes and if your fuse is good try what I said above..
Mon Jul 14, 2014 6:26 am
I mounted a mk battery charger too, had to use cutting boards to mount it to then the boards to the boat, charger itself shouldn't be touching the aluminum.
Sent from my LG-P870 using Tapatalk
Using Tapatalk
Mon Jul 14, 2014 7:05 am
update: after comparing front and back i learned i'm an idiot (shouldnt admit this on MMT) but i found the fuses and need new ones. should be charging this afternoon after i get some new 30 amp fuses.
Mon Jul 14, 2014 7:36 am
Users browsing this forum: No registered users and 107 guests
