best step mats https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=54836 |
Author: | Puddler45 [ Tue Jul 15, 2014 10:47 pm ] |
Post subject: | best step mats |
Well I ended up canceling my hydroturf order because they are out of the wood grain color and it has been discontinued. I ended up getting best step mats at menards because they stock it locally rather than order a different color hydroturf. I got the bow and pod seating pieces cut and glued down . I have 1 section of the floor cut and hope to finish gluing and get the edges trimmed tomorrow after work. Between a 12 pack of past and sniffing Weldwood for a few hours I got one he'll of a buzz |
Author: | doubleBanded [ Wed Jul 16, 2014 5:47 am ] |
Post subject: | Re: best step mats |
That's what I have. It's nice jus make sure u use enough glue to cover the hole surface. And don't hit wit pressure washer to close |
Author: | Puddler45 [ Wed Jul 16, 2014 5:59 am ] |
I do rubber fab for a living and we do quite a few custom belts that have sponge glued to the belts using a contact adhesive. We always do 2 coats each side so that's what im doing for this. Its got plenty of glue definitely will have to grind it off if it needs replacing. |
Author: | GDSArgo [ Wed Jul 16, 2014 8:17 am ] |
That's a working mans beer PBR. Looks good Sent from the company's iPad while at work |
Author: | tinman454 [ Wed Jul 16, 2014 10:47 am ] |
The buzz was from the glue ! No way you got it from that water you guys call beer down there ![]() ![]() ![]() |
Author: | Puddler45 [ Wed Jul 16, 2014 10:57 am ] |
Author: | wisconsin phowler [ Wed Jul 16, 2014 1:15 pm ] |
^ damn right Milwaukee makes great beer...its probably the only thing Milwaukee has...and lake Michigan. I'm the same way, Pabst for everyday drinking and ales/ambers if I want quality. Louie's Demise is some good stuff! Boat is looking good by the way. Did u ever figure out what u are doing with your heads? 1756 Phowler 36PD |
Author: | Puddler45 [ Wed Jul 16, 2014 2:58 pm ] |
Just got the valves and shims today from PVT. I have a 9 day fishing trip leaving friday so I am going to tear into the motor and bring the heads into and get them decked P&P and valves installed after I get back. While that going on Ill port the stock carb to intake adapter to fit the stock 35 HP carb that hopefully came today as well. I am also going to port match the intake as well since its apart. |
Author: | wisconsin phowler [ Wed Jul 16, 2014 4:02 pm ] |
Sounds like you have your work cut out for you. Good luck fishing 1756 Phowler 36PD |
Author: | Puddler45 [ Wed Jul 16, 2014 10:57 pm ] |
Well with help from my good friend pabst and some more ambition I finished laying the flooring. For the most part it went well a few hiccups its not perfect but looks pretty damn good for a hundred buck and a case of beer worth of work. On a side note I got the stock 35 carb from Boat DR I ordered Friday. I was happy to see it had the carb to intake adapter and a fuel line for hook up attached. It saves me some work modifying my 23 hp intake adapter to accept the larger 35 hp carb. The casting is a little rough so if there's a hot bright sunny shitty day for fishing I will do some sanding and polishing the castings on the carb while Im on vacation. |
Author: | Smoke [ Thu Jul 17, 2014 7:43 am ] |
Nice job! Pabst is good beer bros! I do like a Canadian beer called I think Marclays or something like that. We drink a bunch of that when were way north of the border killing SJBP geese. Good stuff! Tinman if you can bring a case of it with you to mayhem ill buy it from ya! Lemme know. next weekend will be a great time at the Mitten Mayhem my Canadian brother! ![]() |
