It is currently Mon Jul 07, 2025 10:20 pm
Reply to topic  [ 13 posts ]
 18/54 pd dented bottom
Post 18/54 pd dented bottom
im starting to see the braces that run the length of my boat from the bottom side. in other words between the braces theres a 1/4 inch difference from many years of toledo bend. several big dents throughout. does this make a noticeable difference in the performance or ride? and are there any alternatives to ****** it? thanks alot. regardless the boat doesnt leak.
Tue Jun 24, 2014 1:22 am
Post Re: 18/54 pd dented bottom
I would also like some feed back on this as well, I'm sure most boats have some dents, what does it hurt if no leaks?
2014 1851swf4/2015 gtr35
DOA decoy company pro staff member
Sun Jun 29, 2014 5:39 pm
Just depends how bad it gets and where they r located. U can lose a few mph, or if it's bad enough boat won't plane. If u haven't noticed a huge loss in performance ride it till the sides fall off
Sun Jun 29, 2014 10:10 pm
If there are dents at the transom creating a wedge effect, then yes you will lose performance.
Mon Jun 30, 2014 7:41 am
oh yea i lost alot of performance with just me in the boat. whith two other peaple it runs great. im worried that flattening the bottom back at will weaken it, and will just be back to the same tunnels and dent the first stumps i hit.
Mon Aug 04, 2014 6:07 pm
http://www.gatorglide.com/
gatorheads@comcast.net
Mon Aug 04, 2014 6:46 pm
So frog your saying not to try some flex steel at the transom hooks? Was gonna maybe try and fill mine before laying the glide
Mon Aug 04, 2014 7:08 pm
Yes that's right! If you are ridding hard enough to put hooks in you bottom you're going to beat the steel flex out fast, when it comes off you have bare aluminum which is like dragging an anchor. Steel flex is designed to be applied about 1/16 thick, if you were to fill anything thicker I would use fasco's ( maker of steel flex) "fast stone #7". To get that to stick you'll need to grid with a 26 grit wheel, clean well and hope. If you take a direct hit its coming out, been there myself, seen it a bunch. But that seem to hold up the longest of any filler myself or the airboat community has found. I went as far as a dust coat of zinc chromate to no avail. If you can beat it out you're better off.
What's it doing to you ride? Is it driving your bow down or just creating drag and how bad?
Mon Aug 04, 2014 7:23 pm
Bow isnt plowing at all, may be creating some drag, but not sure how bad. I got a false floor so theres no way to beat it out without cutting floor
Mon Aug 04, 2014 7:33 pm
Mon Aug 04, 2014 7:50 pm
Sounds good, Ill let her eat! Guess we always looking for that extra mph lol
Mon Aug 04, 2014 7:55 pm
Mon Aug 04, 2014 7:57 pm
Got me 1/2 gallon sitting in the shop now, just need to get in on
Mon Aug 04, 2014 8:02 pm
Users browsing this forum: No registered users and 94 guests
