18/48 Skiff with 36 Pro Drive?
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=55430
Author:  Swamper01 [ Mon Aug 04, 2014 7:39 pm ]
Post subject:  18/48 Skiff with 36 Pro Drive?
Thinking about getting a boat built and was wondering if anyone ran a 18/48 skiff all 3/16 or anything similar with a stock 36 Pro Drive?
I was just wanting to know speeds loaded or unloaded and how it performs
Thanks
And yes i searched and couldnt find anything about it
Author:  Podcast [ Mon Aug 04, 2014 8:09 pm ]
Post subject:  Re: 18/48 Skiff with 36 Pro Drive?
If the skiff is built right yer prolly lookin bout 27-28mph.
Author:  NORTHFLORIDAFOWLER [ Mon Aug 04, 2014 8:27 pm ]
My boats no skiff, but it's 1748 all 3/16 with a stage 2 Prodrive and it runs 34 with just me, fuel and a 20qt yeti. I imagine a stock should push it 26 27 light loaded.
Author:  Swamper01 [ Mon Aug 04, 2014 8:50 pm ]
So im guessing 24/25 range loaded?(boats going to mainly be used for crawfishing)
Author:  Woodiebuster [ Mon Aug 04, 2014 9:19 pm ]
All depends on your definition of a load.
100 sacks of crawfish and some traps is a hell of a load
Author:  Swamper01 [ Mon Aug 04, 2014 9:24 pm ]
Author:  Podcast [ Tue Aug 05, 2014 6:08 am ]
23-24mph is my guess on a stock PD with that load. It all goes back ta the boat and rake design on the hull. Just as important is how ya load it.
Author:  Nate [ Tue Aug 05, 2014 6:20 am ]
Id go 20 ft if its gonna be used for crawfishing...and narrower...say around 44", run a 3/16 bottom and transom, but go with a crimped 1/8 side.
Author:  Swamper01 [ Tue Aug 05, 2014 8:09 am ]
Well i thought about 20/44 but that just seems a little too big for me but i will consider it. But i do need to boat to be all 3/16 because my old skiff i had a few years back had 1/8 sides and the got all messed up
Author:  Will [ Tue Aug 05, 2014 8:12 am ]
If you're getting a Gen 3 PD, it'll be tad slower with a light load but won't be as affected by a heavy load.
Author:  Swamper01 [ Tue Aug 05, 2014 9:31 am ]
So if i get a Gen 2 or 1 PD it will go faster?
Author:  Will [ Tue Aug 05, 2014 9:45 am ]
Not necessarily, the older ones have a higher gear ratio. On a lighter rig, it would/should have more top end, but when weight is added, it will bog the motor easier. The newer ones have a lower ratio and will pull like a tractor. They are also working on higher pitch props for the new ones to gain more speed.
Author:  Swamper01 [ Tue Aug 05, 2014 10:02 am ]
Oh so i would want the Gen 3 PD for this boat then since most of the time its going to be loaded. I got ya but i didnt know the gear ratio was different in em
Author:  Will [ Tue Aug 05, 2014 10:04 am ]
Yes, If it were me, I'd get the Gen 3 since you will have more the the normal load.
Author:  Swamper01 [ Tue Aug 05, 2014 10:52 am ]
Ok thanks
Author:  Woodiebuster [ Tue Aug 05, 2014 1:42 pm ]
The gen 3's are strong motors
I run 29 empty and I'm all over the 4700 rev limiter. I need more prop to go faster.
I can carry 4 men and gear in the mid 20's and still turn 4400-4500 Rpms. Really surprised me
Author:  Swamper01 [ Tue Aug 05, 2014 2:06 pm ]
If i were to put a 3 blade prop would that make a difference in load carrying speeds?
Author:  Woodiebuster [ Tue Aug 05, 2014 7:19 pm ]
They come with a three blade
Author:  Swamper01 [ Tue Aug 05, 2014 7:35 pm ]
Really? I thought they came with 2 blade like GT and then you can put a 3 blade. Well let me ask this,would it run better with a 2 blade?
Author:  North LA Hunter [ Tue Aug 05, 2014 7:50 pm ]
Author:  Swamper01 [ Tue Aug 05, 2014 8:18 pm ]
Yea i saw on the website that motors built after July 2013 all spline props are only available(which are the 3 blade). I also saw that Prodrive doesnt offer manual trim anymore its just hydro
