logriggers
Joined: Sat Oct 13, 2012 7:56 pm Posts: 303 Location: Fairhope, Al
 Tell me what you think about this crazy idea
Ok guys this might be crazy but tell me what you think. I have a ribbed 1648 war eagle. I got a local aluminum guy that said he would cut the bottom off and put a true flat bottom on. The only reason I want to do this is because I like the way the inside of my boat is rigged out. I know I could have a rig built but redoing the bottom is only a fraction of the cost of just redoing the bottom. Let me know what you think.
_________________ 35 Mud buddy Stage 2 on a 1844 Uncle J
Fri Sep 19, 2014 12:29 pm |
BDUBYA
Joined: Wed Apr 25, 2012 2:54 am Posts: 623 Location: Toledo Bend
 Re: Tell me what you think about this crazy idea
I did the same. After one year of hunting the welds had hair line cracks all in them. Getcha a good bilge pump. Bought a new boat this year. Ask your welder about this and see what he says.
_________________ Excel 1851vF86 w/ MB 55V SHIT HAPPENS
Fri Sep 19, 2014 12:38 pm |
btmannin
Joined: Tue Jan 15, 2013 5:25 pm Posts: 1723 Location: Oxford/Jackson ms
I would see the quality of his welds when attaching .100 to 1/8th. I may be wrong, but I've heard it's not an easy task.
_________________ 1436 tin can shoved by a 16 GDLT 16.5x48 running like hell from a built 40 merc
Fri Sep 19, 2014 12:42 pm |
BDUBYA
I had a 3/16" bottom put on. Metal handled good. Not sure exactly what made the welds start cracking but took a can of flex seal a day to finish out the season.
Fri Sep 19, 2014 12:51 pm |
Puddler45
Joined: Thu May 03, 2012 9:07 am Posts: 1199 Location: Wisconsin's waters and woods
boat repairs???? That'll cost you thousands!!!!! just get you some flex seal
_________________ 1744 floating a 23 MBHD Stage 2
Fri Sep 19, 2014 2:09 pm |
brickgw
Fri Sep 19, 2014 2:18 pm |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
BDUBYA
That's why I said fck it. I'm not a professional welder and he acted like he didn't why why either. Said I was being too rough with it. That's a load of BS. So I got a new boat this year. I'm not tryin to tell ya don't do it but that was the outcome I had. And for seal is some bad shit. Tends to peel off once you dry do I it tho. Good luck with it.
Fri Sep 19, 2014 5:52 pm |
ziton
This may sound like malicious engineering. Why cut the whole bottom out? Why not just cut the rib out and plate over? You could cut a slice from the top of the rib then heat and hammer flat, then plate over. It could be welded from the inside and outside. That should solve flex. jmho zz
Fri Sep 19, 2014 7:14 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
Sell that boat. And get one built. You'll be fighting that thing forever. There is a couple of builders that can build you a boat fir roughly 4k.
Fri Sep 19, 2014 8:46 pm |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
Fri Sep 19, 2014 10:51 pm |
North LA Hunter
Sat Sep 20, 2014 2:33 am |
ksgoosekillr
Why not skin it with some 18-20 ga? Wont add much weight will give you the flat without taking away from the structure. Then if it dont pan out cut it off grind it smooth and sell it.
Sat Sep 20, 2014 8:41 am |
Smoke
Joined: Fri Jan 23, 2009 1:27 pm Posts: 1095 Location: SW Michigan
I'd run the boat the way it is before I paid to have it boogered up. IMO your wrecking a good boat someone could use with an outboard. Sell it, take the funds and put some more with it and get yourself a builder to give you the layout just like your current boat.
_________________ 1854 Prodigy Open HDR/Stage 3 mods Prodigy Boats Pro Staff BPS Swamp Staff Member Blackwater Marine LLC.
Sat Sep 20, 2014 9:59 am |
Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
I have a 1542 tracker topper. It is a fukn pop can. I have sooo many fish hooks and dents. It started leaking bad so I gatorglided it this year. All leaks have stopped. That gg has bought me a few more years
_________________ 23 swomp/ 1542 tracker
Sat Sep 20, 2014 4:14 pm |
Colbeans
Welding on thin metal makes it even more brittle meaning won't take to much to mess it up. I agree with getting one built
Sent from iPhone
Sun Sep 21, 2014 11:37 am |
wade_660
My old boat was originally ribbed, then had the bottom replaced with slick .125. Didn't have any problems for two seasons with a long tail on back. Still holding up the last Time I asked about it.
Sun Sep 21, 2014 7:07 pm |
Migrator
Joined: Sun Apr 17, 2011 2:29 pm Posts: 3227 Location: Black River, MS
Some of the custom builders can build you a boat exactly as you want as smoke said. There are plenty folks running outboards that would love to have that war eagle.
_________________ WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
Sun Sep 21, 2014 8:42 pm |
logriggers
so what about just leaving hull and putting another piece right over ribs. I am going to trade some stuff for the metal just have to pay welder. you think it would be a bad idea?
Fri Sep 26, 2014 4:16 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Fri Sep 26, 2014 4:23 pm |
THETANKO1
You could just bondo the entire hull....
Fri Sep 26, 2014 4:28 pm |
brickgw
Fri Sep 26, 2014 4:29 pm |
ziton
Fri Sep 26, 2014 5:02 pm |
