Grab bar console https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=57773 |
Author: | banded-mallard [ Tue Nov 04, 2014 6:22 am ] |
Post subject: | Grab bar console |
I'm looking at adding a small side console for grab bar, switches and cup holder. I've seen a few on here, but curious as to other options. Ordered my switches for to make a switch panel, all are carling waterproof rocker switches with custom faces to distinguish them. Want to make the grab bar removable. 4 bolts and it comes off or possibly a quick pin to remove it. Also will add a cup holder. On the cup holder, do you guys have holes in the bottom to let the water drain, and if so, do you have switches in it like I want to add. Curious as to the electrical with the water and corrosion. Here is a drawing of what I'm possibly looking at. Grab Bar console.jpg |
Author: | thirdtimesacharm [ Tue Nov 04, 2014 6:39 am ] |
Post subject: | Re: Grab bar console |
We use the cup holder for access and put a drain hose on the bottom. Our new grab bar we went to a bolt instead of a pin with three different positions. |
Author: | austin122 [ Tue Nov 04, 2014 1:27 pm ] |
man, why does that boat look so familiar corey? lol |
Author: | banded-mallard [ Tue Nov 04, 2014 2:57 pm ] |
Yeah I thought about putting a drain on the bottom so the cup holder won't fill up with rain water. |
Author: | Bigrich [ Tue Nov 04, 2014 7:39 pm ] |
ImageUploadedByTapatalk1415151591.317856.jpg |
Author: | North LA Hunter [ Tue Nov 04, 2014 8:24 pm ] |
Make it different. They all look the same. Make it have radius corners or something. If I ever build one I'm going to try to think of something to do a little different. Sent from my beeper |
Author: | deadbird8 [ Wed Nov 05, 2014 6:55 am ] |
Author: | Delta1389 [ Wed Nov 05, 2014 9:02 am ] |
My grab bar console is built the same way and will be set up pretty close except my switch panel will be closest to me and has a 12v socket on the panel itself and the cup holder is a plastic insert |
Author: | banded-mallard [ Wed Nov 05, 2014 1:35 pm ] |
Author: | pearl river outlaw [ Wed Nov 05, 2014 1:58 pm ] |
I want to build one that I can put a GPS in the inside of it keep from limbs and stuff trying to rip it off. |
Author: | Delta1389 [ Wed Nov 05, 2014 2:20 pm ] |
Author: | banded-mallard [ Wed Nov 05, 2014 7:13 pm ] |
Decided to just keep it simple. Switches won't be here till sat, so figured I'd get started. image.jpg image.jpg image.jpg |
Author: | Bug [ Wed Nov 05, 2014 9:53 pm ] |
Lookin' good man! |
Author: | msm8281 [ Wed Nov 05, 2014 9:57 pm ] |
Author: | banded-mallard [ Thu Nov 06, 2014 5:53 am ] |
Author: | msm8281 [ Thu Nov 06, 2014 6:43 am ] |
Yes but I will mount it coming off the side instead of off the top. Actually off the front vertical part. |
Author: | banded-mallard [ Thu Nov 06, 2014 7:09 am ] |
