It is currently Mon Jun 30, 2025 3:35 am
Reply to topic  [ 17 posts ]
 Beavertail float pods?
Post Beavertail float pods?
Has anyone ever added the beavertail float pods to their boat. If so was there much of a difference with them on?
Wed Oct 15, 2014 10:19 am
Post Re: Beavertail float pods?
You run a longtail?
Wed Oct 15, 2014 11:38 am
I've put some on and increased ride height in the rear but didn't gain much performance.
Sent from my beeper
Wed Oct 15, 2014 12:11 pm
I put some on back my 14 foot Jon boat gain about 2" in flotation
Wed Oct 15, 2014 7:34 pm
In the back.
Wed Oct 15, 2014 7:37 pm
Thu Oct 16, 2014 11:14 am
you worried its gonna be to much weight on the back
Thu Oct 16, 2014 1:11 pm
Your right about not having the right boat for a MM but that is ok and getting one part at a time is what a lot of guys on here do. Those pods will really help with holding the weight of a MM better and with backwash as well. As for performance, don't expect a lot right now. Get used to how a MM operates, assuming you haven't ran one, and when you get the new hull, then you will realize the true performance the MM will give you.
I think you will be glad you got the pods on that small of a boat.
Good luck and keep us posted on how it does for you.
1752 Uncle J, Calen Stage 1 35 GTR
Thu Oct 16, 2014 2:44 pm
Mon Oct 20, 2014 6:48 am
do you have to have drains on them in your area - we have to up here
Mon Oct 20, 2014 7:12 am
Refurbishing a Prodrive
Mon Oct 20, 2014 8:11 am
POD'S Will help with flotation but majorly hinder the performance of any surface drive MM. Take above ^^^^^^^^^^Advice Learn how the run the motor/Boat combo
1754 With Level 3 GTR
Mon Oct 20, 2014 1:17 pm
I wonder how I every got around with a PD and Beavertail hull combo.
Mon Oct 20, 2014 5:21 pm
Tue Oct 21, 2014 10:45 am
Wed Oct 22, 2014 7:20 pm
Thu Oct 23, 2014 7:54 am
I have pods on my boat with a 35 beavertail SD.. I think it helps in skinny water. I run a lot of wild rice, cattails, etc. No mud flats but in my opinion it helps. Usually takes a bit to get going in shallow water meaning 6" or less but it won't slow down if you are already on plane. My 35 beavertail sd pushes my 1548 alumacraft low 30s with light load and probably 20-25 loaded. I want to get a MM with reverse and a true mud boat but for now mine will do just fine. Hoping the lakes aren't froze next week. Diver and northern mallards should be down in full force and with everyone deer hunting I will be all alone on the lake !!
Sun Nov 09, 2014 3:55 am
Users browsing this forum: No registered users and 135 guests
