Inboard mudboat, need help https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=58330 |
Author: | COONA$$CRAKA [ Sun Nov 30, 2014 9:26 am ] |
Post subject: | Inboard mudboat, need help |
I am wanting to build a 8-10' fiberglass motorize pirogue with a 2.5-5hp motor. I need some help finding the drive system(stump jumper, packing box, steering, etc.) for it. I live in Metairie, LA so if any of my fellow coonasses could help, I'd appreciate it. |
Author: | brycecheramie [ Sun Nov 30, 2014 10:41 am ] |
Post subject: | Re: Inboard mudboat, need help |
Author: | cootshoot [ Fri Dec 05, 2014 2:56 pm ] |
Author: | Marshgator [ Tue Dec 09, 2014 11:16 am ] |
Try these and good luck. Ullo's Hardware-Dept Store 4701 W Bank Expy #4 Marrero, LA 70072 Phone: (504) 341-8512 Alario Bros Commercial Fishing & Marine Supplies, Inc. 894 Avenue A Westwego, LA 70094 Phone: (504) 341-1843 |
Author: | Capt. JJ [ Tue Dec 09, 2014 1:32 pm ] |
Alario's will have everything you need to put it together, stuffing box, flange bearings if you go that route, and the rudder box, but your going to have to build your shaft log or stump jumper and get the shaft made. I've built a bunch of them, and I can't think of anywhere where you can just go buy a stump jumper/strut set up to throw in the boat, it will need to be built. Check out La Sportsman, you will often seen people selling the running gear and strut set ups from mud boats on there. Last one I built I bought my shaft wheel and clutch off of sportsman for a deal. Justin |
Author: | redlined_b16a [ Mon Dec 22, 2014 6:23 am ] |
If you have acess to a torch and welding machine a simple steel set up is pretty easy to make out of 1 1/4" pipe, a cutlass bearing for the bottom and a rope packing at the top.14 degree angle.I have never seen a factory made. |
Author: | redlined_b16a [ Mon Dec 22, 2014 6:24 am ] |
Author: | dguidry [ Mon Dec 22, 2014 8:36 am ] |
8' to 10' pirogue...you must be a little bitty fella. I'd go at least 15', |
Author: | latravcha [ Mon Dec 22, 2014 11:04 am ] |
http://www.louisianasportsman.com/lpca/ ... &id=575978 Cheaper than you can build it. |
Author: | redlined_b16a [ Mon Dec 22, 2014 11:41 am ] |
once motorized it will have to be inspected and and registered with numbers,unless your on private property.In Louisiana anyway. |
Author: | COONA$$CRAKA [ Fri Jan 02, 2015 11:53 pm ] |
I saw that pirogue for sale already. I have a 14' but Id rather go smaller and lighter, so I can throw it on my mounts on my boat. This is going to be use to pick up ducks and decoys. Im not looking to go fast and I dont want a trolling motor. Im thinking at most, a 10' boat with a 2' bottom at the widest. Ill make the boat out of fiberglass covered foam. if I have to Ill make a flat back and run the shaft out the transom. What do you think, possible or not so much? |
Author: | COONA$$CRAKA [ Fri Jan 02, 2015 11:55 pm ] |
I saw that pirogue for sale already. I have a 14' but Id rather go smaller and lighter, so I can throw it on my mounts on my boat. This is going to be use to pick up ducks and decoys. Im not looking to go fast and I dont want a trolling motor. Im thinking at most, a 10' boat with a 2' bottom at the widest. Ill make the boat out of fiberglass covered foam. |
Author: | Marshmaster45 [ Sat Jan 03, 2015 5:02 am ] |
Gonna be a bit squirrelly . |
