Mud buddy https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=58706 |
Author: | Av8rgh [ Mon Dec 15, 2014 6:28 pm ] |
Post subject: | Mud buddy |
I'm having issues with my 1648 Waco over plaining with my mud buddy 35 surface drive. Any tips or things I can do to prevent this? Will a piece of square tubing between the motor an transom help? Thanks Sent from my iPhone using Tapatalk |
Author: | rhock19 [ Mon Dec 15, 2014 6:36 pm ] |
Post subject: | Re: Mud buddy |
What do you mean by over planing? |
Author: | cb5331 [ Mon Dec 15, 2014 6:39 pm ] |
Porpoising? |
Author: | msm8281 [ Mon Dec 15, 2014 6:40 pm ] |
Author: | Smoke [ Mon Dec 15, 2014 6:45 pm ] |
There is a shim that comes with the motors that should take care of the problem. I personally never needed it on either of my boats. |
Author: | Av8rgh [ Mon Dec 15, 2014 9:23 pm ] |
Over planing meaning nose of boat is getting pushed down in water, it's not hopping just plowing a lot of water. Any tips to fix this? Sent from my iPhone using Tapatalk |
Author: | 270Handiman [ Mon Dec 15, 2014 11:03 pm ] |
Never heard of this on a mud boat. Sounds like either to much weight in the front of the boat, or your not trimming up high enough. Otherwise, with you and a 350 lb. motor on the back of a 16' boat, the bow should be wanting to lift. What condition is the bottom of the boat in? Does it have a bunch of hooks? |
Author: | deadbird8 [ Fri Dec 19, 2014 7:18 am ] |
As stated above, the transom angle may be off from whats recommended, you can try shimming it. (that assumes you have exhausted distributing the load in the boat) |
