It is currently Sun Jun 29, 2025 10:26 am
Reply to topic  [ 19 posts ]
 Need more power
Post Need more power
I have a 2007 PD XSeries w/36hp Vanguard. I hunt 2 to 3 guys, dog, decoys ect... The rig struggles with the load, barely makes 13mph. Any ideas, engines turns up to 4300 rpms, not sure what to change.
Mon Dec 29, 2014 5:14 pm
Post Re: Need more power
4300 rpms in gear with a load?
Mon Dec 29, 2014 9:21 pm
How worn is your prop? Has it always been this way?
Mon Dec 29, 2014 9:27 pm
Check prop first, hooks in the back in front of the motor, then the motor itself. Leaking valves on the stock motor is a common issue which robs power from the motor. This is why headwork and high flow exhaust is recommended as the first items to address when adding performance. Most will see night and day performance from headwork, which usually is addressing leaking valves.
Tue Dec 30, 2014 9:03 am
Unbolt that vanguard, sell it, and buy a Kawasaki 35. You won't ever have that issue again. ;)
Tue Dec 30, 2014 11:34 am
So his prop won't ever wear out with a kawaski?
Tue Dec 30, 2014 2:20 pm
If your turning 4300 Rpms loaded then I'd def. Check your prop size prob worn out. Not sure what prop your running but it should be at least 12" across.
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Tue Dec 30, 2014 3:57 pm
Put a prop on it, Ask Cootslayer how much a new one can help.
16X48 WELDBILT -25GTR EFI-sold
18x48 GTB - 35 GTR
Crown royal pro-staff
Tue Dec 30, 2014 4:10 pm
Get a Kawasaki and pledge "team Kawasaki" and make it through hell week. Then you can tell everyone that has a power issue to get a Kawasaki and all your troubles will be solved.
Go team KAWASAKI!!!!
Try a new prop first. If it turns out that ain't you have an extra prop that you'll need one day.
Tue Dec 30, 2014 4:17 pm
Buying one kawaski seems cheaper than a lifetime of props
Tue Dec 30, 2014 6:24 pm
Tue Dec 30, 2014 6:39 pm
I actually am not against them. I think it's a great idea however they have yet to prove themselves. I have to run stick motors and no one leaves them stock. There also isn't a single one out there with 1500 hours. My shitty vanguard us around 1300-1400 hours and i am still on my first case gasket, still pass a leak down and still runs every load i put in it.
Tue Dec 30, 2014 6:59 pm
Only thing i wish my motor did better was idle under a load and was easier to start in the morning. EFI will solve that problem
Tue Dec 30, 2014 7:00 pm
Tue Dec 30, 2014 7:45 pm
I'm running a three blade for the power, and it will run 28-29 empty. I have a two blade that is supposed to be a little faster, will change tomorrow to see. A buddy told me to get a new cam, and have the valves re worked?
Tue Dec 30, 2014 8:17 pm
Tue Dec 30, 2014 10:23 pm
Wed Dec 31, 2014 6:20 am
Wed Dec 31, 2014 6:21 am
https://m.youtube.com/watch?v=bdP9ThANFzU
Wed Dec 31, 2014 7:32 am
Users browsing this forum: No registered users and 152 guests
