It is currently Tue Jul 01, 2025 10:27 pm
Reply to topic  [ 8 posts ]
 Bout to be overpowered i believe
Post Bout to be overpowered i believe
Just bought a 18hp go devil crawfish model. Gotta rebuild the carb and then shes going on my little skiff. 14x32.. Got a few questions tho.. First off what yall know ab that 18 hp? Good motor? The frame is a 2005, in excellent condition. I just never hear anything about that 18hp vanguard.
Also will i be able to run this thing safely? Heres a pic of the boat
19x48 rickey aucoin bateau
37efi gtr
Sat Dec 20, 2014 6:44 am
I started off with an 18hp on a 14*32. It was a bateaux not a skiff but did ok for being a tin can. The motor is a work horse, I bought mine used with no telling how many hours on it and I put it through hell as well. Never had an issue. The only issue with the setup is that it was a 20" transome and these motors are made for 16". You can adjust the cavitation plate to help with it wanting to blow out. Also your back seat will be in the way of the handle bar. I would add a grab bar also. Have fun and wear the kill switch. I mean it wear the kill switch!
17*38 Klibert 23GDLT
Sat Dec 20, 2014 8:00 am
Post Re: Bout to be overpowered i believe
What mr da go getter said. . Definitely add some type of grab bar , and wear your kill switch . Just get some stick time and practice turning at speeds. . Also watch sudden stopping as water usually wants to come over stern . You'll get the hang of it soon . Enjoy and post up speeds and review after you get some time in it . Longtails tend to favor long skinny boats .
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Sat Dec 20, 2014 8:58 am
Definetly adding a grab bar asap. Just gotta get the welding machine back from a buddy again. Im glad to here what im planning has been done before. Ill def post after i run it ab speed an sketchyness. Any special precautions ab the engine or anything. This is my 2nd go devil but the first was a junker homemade job so idk if that couns
37efi gtr
Sat Dec 20, 2014 12:38 pm
Well we had the maiden voyage today. It went pretty well. Motor wasnt running 100% but we got to prove she floats the motor. It sits kinda low an we took on water a few times but it was managable. Gps said 15mph w two people and 17 with one. It doesnt really get on top tho. Its like a half azz plane. Once i get the motor running right it should bump 20. I had to run it on half choke or it would surge and kill.
37efi gtr
Sun Dec 21, 2014 7:17 pm
Sounds like u got urself a dirty carb!
Wed Dec 24, 2014 6:39 pm
I squats in the back because the boat is so dang small. It would run better on a much larger hull.
Thu Dec 25, 2014 12:06 pm
Little update, done some welding on the boat. I added some hight to the sides and transom, added a grab bar, and added some trim tabs to hopefully get it out the water somemore on plane. Unfortunatly motor is still not running right. Im gonna have to take it to someone i think. Anyway, i think the boat is pretty squared away. What yall think?
37efi gtr
Tue Jan 06, 2015 8:38 pm
Users browsing this forum: Google [Bot] and 134 guests
