Winching my boat??
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=59250
Author:  Qqmf2014 [ Sat Jan 10, 2015 12:12 pm ]
Post subject:  Winching my boat??
So I would like to hunt an area near me but to get to it you must cross a levee. Its about 100' and about 12-15' high at the peak. My question is, can i attached a winch to the front hook on my boat and pull it without screwing it up? I would use a 2000lb winch attached to a t-post and the wire attached to my boat. Its a lowe 1648 with 35GDsd
Thanks
Dont want to mount a winch to the front since I will only use it occasionally.
Author:  Gigafowl [ Sat Jan 10, 2015 12:26 pm ]
Post subject:  Re: Winching my boat??
Sure just cut you 6 4foot sections of 1" pvc and lay then out
in front of the boat every 3 feet or so --- sink an anchor on
the far side of the levy to winch from and you can likely just
push it down the other side by hand with a handy 2x4....
I keep 2x4s and pvc in the boat at all times....
Author:  BayouBuster [ Sat Jan 10, 2015 7:02 pm ]
Gator glide will help with this.
Author:  Smoke [ Sun Jan 11, 2015 12:35 pm ]
I use 1 1/2" PVC because of rock etc. not sure if the eye hook on your boat is welded or bolted. That would make a difference too. 2000# winch might be undersize for a dead pull. Might wan to look into a chain saw winch. We use them here all the time. There called Lewis winches.
Author:  Qqmf2014 [ Sun Jan 11, 2015 1:31 pm ]
The levee prolly has about a 20degree incline. Would be pulling over an airboat trail.
Author:  westsidemi [ Tue Jan 13, 2015 7:11 pm ]
Author:  GDSArgo [ Tue Jan 13, 2015 7:21 pm ]
Chain saw winch? The stuff I see on MMT never stops amazing me.
Sent from the company's iPad while at work
Author:  westsidemi [ Tue Jan 13, 2015 7:26 pm ]
Like Smoke said, we have several managed areas around here that are impoundments. One in particular that has a few long dykes to pull, especially depending on water levels. There have been times the longest pull was nearly 150', and roughly 20' up and down.
Author:  Frog [ Wed Jan 14, 2015 5:37 am ]
;) . <<<<<< GatorGlide
