It is currently Sun Jun 29, 2025 6:05 am
Reply to topic  [ 19 posts ]
 19x52 3X taper info
Post 19x52 3X taper info
Guys I'm finalizing the design of my WC custom boat and have a concern on stability. The boat will be 19' x 52" 3/16. I'm doing a 3x Chine.
I want the boat to turn well and also carry a load. My question is when do I start the 3x chine. Do I start after the 52". I want stable boat. My buddies 1648 is super unstable.
Thank you
Fri Jan 16, 2015 8:15 pm
Post Re: 19x52 3X taper info
Is your buddies boat a triple tapered chine?
Fri Jan 16, 2015 10:38 pm
Most people have the bottom measurement (52" in your case) as the width of the actual flat part of the bottom. A 19' by 52" will be pretty stable.
Fri Jan 16, 2015 10:50 pm
My 18/56 is super stable , you shouldn't have any issues .
Fri Jan 16, 2015 10:55 pm
My 44" double taper WC boat .. Is as stable as 54 GT boat ..
Me 250 and a buddy 250 can both stand in front deck and fish no problem .. We put it to the limit by both standing on rail
1744 WC Custom
25 GTR
Fri Jan 16, 2015 11:05 pm
Sat Jan 17, 2015 7:31 am
From what I have seen the difference in stability because of th chine is minimal. It you want stability get a wider boat
Sat Jan 17, 2015 7:44 am
Agree ^. Boat makers have nothing to do with the stability. A square chine prodigy and a square chine uncle j of the same length and width would have the same stability !
Well in theory I would agree. However, the 2 makes would have to build identical weighted boats with the weight distrubtion exactly the same. The more evenly weighted boat will be more stable. If the two boats are built correctly thou, you probably wouldn't notice a difference unless you were jumping back and forth to compare
Sat Jan 17, 2015 7:53 am
Loved my Uncle J 18X54 3/16. Boat was a beast. Fast as heck and carried a load great. It was a square chine boat. The issue I had was turning at speed. The boat would slide.
I want a fast boat that will carry a load and turn at WOT. The stability is an issue as well.
Can one boat do all this and run 30 mph , stage 2 ??
Thanks !!
Sat Jan 17, 2015 9:38 am
I'd get a square chine if they didn't slide so bad on the turns. The bayou on the way to my lease is oxbow . Would have to throttle down every turn. You go 10 miles just to drive 5 lol. That's why I'm going with a triple chine. But I do like how well the square chimes carry a load.
Sun Jan 18, 2015 1:03 am
I have a 2054 square chine 3/16 hull as well and it does slide in turns. You have to slow down but its a superfast hull and carrys a load very well. If I had it to do over I would go back with another square chine because u dont have to slow down that much to make a turn and I had rather have the speed and load carrrying ability.
Sun Jan 18, 2015 8:20 am
Bow rake and angle has way more to do with stability
at dead stop than chine design - remember several feet
of many hulls are not even in contact with the water....
Your sketch shows a 7 foot bow rake and an 11x52 contact pad...
A lot of 16x48 hulls have bigger contact pads - that might be
a bigger concern or concept to think over ??? Long bow rakes
are faster at WOT but give up some stability at dead stop....
Sun Jan 18, 2015 9:22 am
Something to chew on for a while... Round chine boats will be more stable if they're measured by the actual flat bottom width because you have more boat in the water at a stop. Food for thought.
Sun Jan 18, 2015 5:13 pm
Sun Jan 18, 2015 5:35 pm
Thanks guys for the input !!
I will get with Pete at WC to talk about the rake and other items.
Sun Jan 18, 2015 5:37 pm
Sun Jan 18, 2015 6:54 pm
The area I hunt is called fish eating creek. Located in Palmdale Fl. They open up the check station at 5 AM. I got a 15 mile cypress infested dark run to my spot. Takes me about an hour. Crazy turns cypress heads multiple collisions it's crazy. If you miss the trail you wont find out until your 100yards in. The place is loaded with dear & hog
I added a pic shows a .2 mile segment. We do 15 miles in and 15 out.
Sun Jan 18, 2015 8:56 pm
lol drive 15 miles and really only go 5 miles lol. doesn't help crab traps in the way. anyone who has a triple chine on here , how do u like it ?
Sun Jan 18, 2015 9:33 pm
Users browsing this forum: Google [Bot] and 135 guests
