LED strip lights https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=59519 |
Page 1 of 2 |
Author: | capt.josh [ Wed Jan 21, 2015 2:20 pm ] |
Post subject: | LED strip lights |
Where are yall mounting them and how many? I bought some that are like 21" long. I've got some ideas just wondering what everybody else is doing. |
Author: | dom [ Wed Jan 21, 2015 2:24 pm ] |
Post subject: | Re: LED strip lights |
i mounted ones a lot longer thn that under my catwalks. |
Author: | GeorgiaRiverRunner [ Wed Jan 21, 2015 3:00 pm ] |
If you haven't opened them and can send them back, do. Ching chong on Ebay has a 20 ft strips for something like $10. Get you a couple of those and you run them around the entire gun rail. Just an idea. |
Author: | capt.josh [ Wed Jan 21, 2015 3:10 pm ] |
Yeah I haven't opened them and I saw those long ones that you can cut |
Author: | deerman101 [ Thu Jan 22, 2015 8:20 am ] |
I used the 21" strips as well it took me 7 to do mine and I put them under the catwalk and front deck. I just soldered the strips together make a longer strip. yes the 20ft strip would of been the easiest route to take and would eliminated a lot of the soldering process but that only took me about 15 min to do. |
Author: | duckduckboom [ Thu Jan 22, 2015 2:33 pm ] |
I got a 16' role of of Amazon for like $15 |
Author: | sas8819 [ Thu Jan 22, 2015 2:36 pm ] |
X2 on the 16 ft amazon ones. |
Author: | baron von [ Thu Jan 22, 2015 2:39 pm ] |
Author: | deerman101 [ Fri Jan 23, 2015 7:41 am ] |
Author: | baron von [ Fri Jan 23, 2015 7:44 am ] |
Author: | LAduckbuster [ Fri Jan 23, 2015 7:48 am ] |
Author: | LAduckbuster [ Fri Jan 23, 2015 7:49 am ] |
These are the 16' strip off Amazon I cut it in the middle |
Author: | baron von [ Fri Jan 23, 2015 7:56 am ] |
the Amazon led strips are pretty easy to work with - they cut clean and use a little silicone to secure in place - I used door bell wire to wire them in, |
Author: | 270Handiman [ Fri Jan 23, 2015 11:16 am ] |
Has anybody had both red and green, for comparison? |
Author: | msm8281 [ Fri Jan 23, 2015 5:51 pm ] |
Red white and blue all at one time would be sweet... ![]() |
Author: | GeorgiaRiverRunner [ Fri Jan 23, 2015 6:11 pm ] |
The ones I got off Ebay can do a wide range. Here is a link: |
Author: | Will B Free [ Mon Mar 30, 2015 7:39 pm ] |
Dumb question but how do these hook up to a battery source? |
Author: | duckduckboom [ Mon Mar 30, 2015 7:56 pm ] |
postive to postive negative to negative |
Author: | Will B Free [ Mon Mar 30, 2015 7:59 pm ] |
I guess I should have clarified...do they come with cables that hook straight to the battery? Or do I need to buy some adapter? Thanks |
Author: | duckduckboom [ Mon Mar 30, 2015 8:01 pm ] |
they come with about 6" of wire coming of both sides . you just need to add the correct connector for you application. |
Author: | Will B Free [ Mon Mar 30, 2015 8:05 pm ] |
Author: | Will B Free [ Mon Mar 30, 2015 8:08 pm ] |
Anyone have the link to the particular brand they like? I know they are pretty generic it seems but all yalls look good. |
Author: | tyler_johnson [ Mon Mar 30, 2015 8:16 pm ] |
I get mine from superbrightleds.com Pay quite a bit more but I like red, and the smaller chipset outshines the cheaper larger chipset, and that's where I get all of mine, I did install the supernight leds from amazon in 3 different friends boats so far but those were green and white, their green is bright as shit, and $15 a 15ft roll. |
Author: | Will B Free [ Mon Mar 30, 2015 8:23 pm ] |
Author: | tyler_johnson [ Mon Mar 30, 2015 8:36 pm ] |
Rspade connectors basically, if I tried to explain my wiring diagram of my boat it wouldn't happen, just hook your positive to positive and negative to negative, just like anything else. |
Author: | banded-mallard [ Tue Mar 31, 2015 4:51 am ] |
Author: | Will B Free [ Tue Mar 31, 2015 7:57 am ] |
Author: | micahb [ Tue Mar 31, 2015 9:30 am ] |
Can you cut them up in different lengths and solder pigtails on them for multiple locations? |
Author: | banded-mallard [ Tue Mar 31, 2015 10:29 am ] |
the ones I had, yes. There are designed marks where you had to cut. But you would have to gently cut back some the the plastic to expose the terminals and then solder new wires to it. |
Author: | doubleBanded [ Tue Mar 31, 2015 10:31 am ] |
Author: | huck Finn [ Tue Mar 31, 2015 10:34 am ] |
Author: | Fooshman [ Fri Apr 03, 2015 2:31 pm ] |
For the guys that are mounting them under the catwalks, are yall centering them under the walk or what? |
Author: | tyler_johnson [ Fri Apr 03, 2015 4:25 pm ] |
Wait til dark, play with placement and figure out where you like your light, peel then place. Easiest way to me. |
Author: | Fooshman [ Fri Apr 03, 2015 9:53 pm ] |
Author: | Will B Free [ Sat Apr 18, 2015 10:36 am ] |
do y'all run a surge breaker on these? |
Author: | msm8281 [ Sat Apr 18, 2015 3:22 pm ] |
Author: | Will B Free [ Sat Apr 18, 2015 3:35 pm ] |
Author: | Terraboat [ Sat Apr 18, 2015 7:56 pm ] |
For long term reliablity, best to run waterproof fuse holders to stop corrosion. Especially if running in salt water . I also spray contacts with a little corrosion x before I close water proof lid. They are only about 2-5 bucks a fuse a fuse holder. |
Author: | sela_native [ Sun Apr 26, 2015 10:27 pm ] |
Pictures of my boat layout. I wired one set backwards for a comparison shot. Supernight rgb leds. 12 different colors plus a dimming option. |
Page 1 of 2 | All times are UTC - 6 hours |
