It is currently Sat Jun 28, 2025 5:41 pm
[ 5 posts ] |
Making an aerator a wash down.
sthomp
Joined: Mon Aug 22, 2011 4:46 pm Posts: 164 Location: Alabama
I replaced the console in my boat that had livewell with one that doesn't so now I have an aerator that can't be used. My thought was I might could re-plumb it and add a hose bib to convert it to a raw water wash down. Do they produce enough pressure and flow? It takes about 5 mins to fill the 16 gal livewell (just guessing I've never timed it) so 3-5 gpm and most wash downs have less flow. Could it work?
Fri Mar 06, 2015 8:05 am |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re: Making an aerator a wash down.
It won't be great, not enough pressure. But, you can use the same thru-hull, add a jabsco wash down pump, plumb it out and be golden.
Fri Mar 06, 2015 8:56 am |
pearl river outlaw
Joined: Wed Jul 28, 2010 9:12 am Posts: 1407 Location: Louisville Ms
Use to have one on my fan boat for bowfishing after the deck got slimmy hose it down and pump it out........
_________________ Back Yard Bullshit 1848 with Delta stage II cam & heads, MAC, with a Mikuni juice pump.
No I wasn't talking about you but if the shoe fits lace that bitch up & wear it!!!!
Fri Mar 06, 2015 9:32 am |
LB200
You could do above with a real wash down pump which has higher pressure with lower GPH. You could pick up a larger bait well pump, like a 1100 GPH or 750 GPH, they do not create the pressure of a wash down pump but would give a decent amount of flow if the hose was not too long
Fri Mar 06, 2015 12:09 pm |
sthomp
If I can't do it with the pump I have I'll just get the real deal. I thought maybe I might could make due for awhile with what I have, but I guess I'll get a wash down pump.
Fri Mar 06, 2015 5:24 pm |
[ 5 posts ] |
Users browsing this forum: No registered users and 136 guests |
