Making an aerator a wash down.
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=60607
Author:  sthomp [ Fri Mar 06, 2015 8:05 am ]
Post subject:  Making an aerator a wash down.
I replaced the console in my boat that had livewell with one that doesn't so now I have an aerator that can't be used. My thought was I might could re-plumb it and add a hose bib to convert it to a raw water wash down. Do they produce enough pressure and flow? It takes about 5 mins to fill the 16 gal livewell (just guessing I've never timed it) so 3-5 gpm and most wash downs have less flow. Could it work?
Author:  270Handiman [ Fri Mar 06, 2015 8:56 am ]
Post subject:  Re: Making an aerator a wash down.
It won't be great, not enough pressure. But, you can use the same thru-hull, add a jabsco wash down pump, plumb it out and be golden.
Author:  pearl river outlaw [ Fri Mar 06, 2015 9:32 am ]
Use to have one on my fan boat for bowfishing after the deck got slimmy hose it down and pump it out........
Author:  LB200 [ Fri Mar 06, 2015 12:09 pm ]
You could do above with a real wash down pump which has higher pressure with lower GPH. You could pick up a larger bait well pump, like a 1100 GPH or 750 GPH, they do not create the pressure of a wash down pump but would give a decent amount of flow if the hose was not too long
Author:  sthomp [ Fri Mar 06, 2015 5:24 pm ]
If I can't do it with the pump I have I'll just get the real deal. I thought maybe I might could make due for awhile with what I have, but I guess I'll get a wash down pump.
