bilge discharge on a hunt deck
https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=60616
Author:  dwight37 [ Fri Mar 06, 2015 2:00 pm ]
Post subject:  bilge discharge on a hunt deck
Getting everything wrapped up on new hull and was needing ideals on where everyone has their discharge hose and thru hull connector on their hunt deck hull
Wanting to keep it from looking too ghetto
Author:  krazo [ Fri Mar 06, 2015 2:02 pm ]
Post subject:  Re: bilge discharge on a hunt deck
Mine is on the side of the boat.
Author:  krazo [ Fri Mar 06, 2015 2:07 pm ]
Like this
Author:  dwight37 [ Fri Mar 06, 2015 2:11 pm ]
Back under the deck?
Author:  dwight37 [ Fri Mar 06, 2015 2:18 pm ]
Ya got a inside pic of it?
Just my luck I'd rip the hose into if it's up high on the wall
Author:  krazo [ Fri Mar 06, 2015 2:27 pm ]
It is under the catwalk
Author:  270Handiman [ Fri Mar 06, 2015 3:02 pm ]
Side discharge like above is the way to go.
Author:  Smoke [ Fri Mar 06, 2015 3:59 pm ]
On the port side right in front of the drop deck. I've got twin 1500 gph rules with a jr. System. So I've got two outlets coming out the side of the boat. Pumps so much water I can almost steer with it. :lol:
Author:  270Handiman [ Fri Mar 06, 2015 4:23 pm ]
Author:  BayouRunner [ Fri Mar 06, 2015 5:27 pm ]
Put two in mine as well. Put a 500 gallon automatic for when I leave the boat in the water and have a 1500 gallon one as well. May seem like overkill but I've been boating a long time. Sooner or later that one time you have it you will be glad it's there. Both come out the side as well. Not wired on the same fuse
Author:  baron von [ Fri Mar 06, 2015 5:40 pm ]
Author:  DmaxHunter [ Sat Mar 07, 2015 7:15 am ]
Mine exits out side aswell
Author:  msm8281 [ Sat Mar 07, 2015 8:13 am ]
Out the side. Make sure to get the 90 degree fitting!!
Author:  dwight37 [ Sat Mar 07, 2015 2:32 pm ]
Alright a 90 deg fitting is the ticket
Thanks guys
Author:  gfowel [ Sun Mar 08, 2015 4:23 am ]
Here's mine.
Author:  msm8281 [ Sun Mar 08, 2015 6:50 am ]
^^^^What battery is that?
Author:  WestEndAngler [ Sun Mar 08, 2015 7:47 am ]
Mine goes right out onto the hunt deck and off the back of the boat. No issues at all.
Author:  Maclavin [ Sun Mar 08, 2015 8:30 am ]
Twin automatic 1100's
Author:  GatorDubea [ Sun Mar 08, 2015 8:39 am ]
Author:  gfowel [ Mon Mar 09, 2015 6:32 am ]
Author:  petrel [ Mon Mar 09, 2015 7:38 am ]
I don't have a hunt deck, but my bilge pumps just discharge over the transom. It saved drilling holes in the hull, eliminated the need for angled fittings that can reduce flow, and I didn't have to make room for riser loops to prevent back flow.
