It is currently Sat Jun 28, 2025 12:14 pm
Reply to topic  [ 15 posts ]
 New aluminum
Post New aluminum
What do they use to protect aluminum (glycol, oil, peanut shells?) when shipping. What could be in the "new" aluminum that could make paint and even an etching primer peel? Got a customer that the entire boat is peeling in big sheets.
http://www.gatorglide.com/
gatorheads@comcast.net
Wed Mar 25, 2015 6:50 pm
Post Re: New aluminum
light machine oil from the uncoiler before the sheer would be my guess where was the aluminum form usa or china ? you could ask aloca what they use after making it into a coil before its get sold to a reseller that cut it down the sheets
1236 Appleby
1436 Alumacraft Go-devil 5hp crawfish
1452 Delhi
Alumcraft waterfouler 16 beavertail 35hp sd
viewtopic.php?f=17&t=59558
Wed Mar 25, 2015 7:12 pm
No anchor profile and/or not enough acetone.
Wed Mar 25, 2015 7:15 pm
Best way to etch alum good is run over it with some kind of sandpaper and cover it well then take a strong degreaser like purple power and spray it on and let it foam white for a 5 min or so then wipe with thinner and you ready to go.
Like said above there is a light sheen of oil on all new flat sheets.
Some alum you get has paper between the sheets but most have nothing.
Sent from my beeper
Wed Mar 25, 2015 8:14 pm
I've gotten some with some kind of coating on it before. Not sure what it was, but it had to be removed to weld on or it would make a mess.
Wed Mar 25, 2015 8:36 pm
Wed Mar 25, 2015 9:42 pm
Thu Mar 26, 2015 4:53 am
Thu Mar 26, 2015 4:58 am
Thu Mar 26, 2015 5:57 am
What about ospho?
1748 Cottonmouth Hybrid Custom with a 2015 35GTR
7 yr old Boykin Spaniel
One Badazz wife that that hunts like a champ
ROLL TIDE!!
Thu Mar 26, 2015 1:49 pm
Frog,
Since I am thinking this is boat in the other thread...
I believe it says that boat was painted. Not raw.
If so, could it be something with the paint that was on there or some sort of clear coat that is keeping it from bonding?
I had a similar peeling that happened when I painted over paint on another boat. On the boat the paint "was almost gone" as described in the other thread, and so I didn't sand it very much at all. very light scuffing.
I know that was paint and not GG, but just trying to help you sort it out.
Thu Mar 26, 2015 2:14 pm
Thu Mar 26, 2015 7:04 pm
Thu Mar 26, 2015 8:29 pm
Post New aluminum
95% of paint failure is prep. 4% is application.
1% is the actual paint.
And I've been in this business for over half my life.
You cannot get it too clean. Grease or wax will affect adhesion. Plus paint adheres mechanically so the rougher the surface the better.
Thu Mar 26, 2015 9:18 pm
Thu Mar 26, 2015 9:59 pm
Users browsing this forum: No registered users and 137 guests
