It is currently Fri Dec 19, 2025 7:42 pm
[ 7 posts ] |
NTXbighorn93
Joined: Fri Jan 30, 2015 10:16 am Posts: 101 Location: North Texas
 Hull painting
Getting ready to order a hull and to save a little cash I'm gonna paint it myself. I have access to a shop an HVLP spray gun setup, is this the best route or will I be just as well off to rattle can it? Also what kinds of paint and primer are you using? Also installing gator glide so I'm curious which order would be best to put them on? Thanks y'all
_________________ 1854 Uncle J sport deck with a 36 prodrive
When in doubt throttle it out!
| Thu Jun 25, 2015 7:39 am |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
 Re: Hull painting
If your going to glide, leave the bottom bare.
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
| Thu Jun 25, 2015 7:52 am |
NTXbighorn93
 Re: Hull painting
That's the plan, what kind of prep do I need todo to the bare alum to get primer to stick right?
| Thu Jun 25, 2015 8:34 am |
baron von
Joined: Tue Jan 21, 2014 2:52 pm Posts: 2806 Location: Minnesota
 Re: Hull painting
use the search feature located in the top tool bar, there was a lot of guys in the past that have done it many ways with a lot of success stories. viewtopic.php?f=4&t=59707&hilit=painting
_________________ that's going itch when it dries
| Thu Jun 25, 2015 9:26 am |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
 Hull painting
I would spray it with a hvlp gun. And don't get cheap paint either. The cheap flat paint is very chalky and does not hold up.
I seem to have good luck with Nason paint. It's a DuPont paint.
For primer I use a 2 part etching primer. Many paint store should have it. Or you could get wash primer from Sherwin Williams
Sent from my beeper
| Thu Jun 25, 2015 9:41 am |
NTXbighorn93
 Re: Hull painting
| Thu Jun 25, 2015 10:12 am |
Mudhole
Joined: Wed Jan 14, 2009 7:05 am Posts: 716 Location: NW La.
 Re: Hull painting
With a bare hull you need to use a primer made for alum!! I ordered my paint from Lock Stock and Barrel, a gallon for base coat and a quart each for the other two colors (Natgear) that was years ago and not one scratch on the hull to date!!!
_________________ "Gofer Everette?"
| Fri Jun 26, 2015 10:18 am |
[ 7 posts ] |
