It is currently Fri Jun 27, 2025 5:15 pm
Reply to topic  [ 7 posts ]
 Hull painting
Post Hull painting
Getting ready to order a hull and to save a little cash I'm gonna paint it myself. I have access to a shop an HVLP spray gun setup, is this the best route or will I be just as well off to rattle can it? Also what kinds of paint and primer are you using? Also installing gator glide so I'm curious which order would be best to put them on? Thanks y'all
1854 Uncle J sport deck with a 36 prodrive
When in doubt throttle it out!
Thu Jun 25, 2015 7:39 am
Post Re: Hull painting
If your going to glide, leave the bottom bare.
Thu Jun 25, 2015 7:52 am
That's the plan, what kind of prep do I need todo to the bare alum to get primer to stick right?
Thu Jun 25, 2015 8:34 am
use the search feature located in the top tool bar, there was a lot of guys in the past that have done it many ways with a lot of success stories.
viewtopic.php?f=4&t=59707&hilit=painting
Thu Jun 25, 2015 9:26 am
Post Hull painting
I would spray it with a hvlp gun. And don't get cheap paint either. The cheap flat paint is very chalky and does not hold up.
I seem to have good luck with Nason paint. It's a DuPont paint.
For primer I use a 2 part etching primer. Many paint store should have it. Or you could get wash primer from Sherwin Williams
Sent from my beeper
Thu Jun 25, 2015 9:41 am
Thu Jun 25, 2015 10:12 am
With a bare hull you need to use a primer made for alum!! I ordered my paint from Lock Stock and Barrel, a gallon for base coat and a quart each for the other two colors (Natgear) that was years ago and not one scratch on the hull to date!!!
"Gofer Everette?"
Fri Jun 26, 2015 10:18 am
Profile YIM WWW
Users browsing this forum: No registered users and 125 guests
