ETX
New Member
 Boat won't get on plane question.
I have a 1860 hull with a 37 EFI gatortail. The boat wont get on plane for some reason. The bottom of the hull isnt perfectly flat side to side and is slightly "U" shaped. Its a center console with minimal stuff in the boat itself. Just the basics, gas tank up front, battery in the back, trolling motor and thats about it. It just seems like I cant get the front of the boat down. I have tried adding a person to the front and still no dice. Any suggestions as to how I can fix this problem would be great!
| Mon Jun 29, 2015 2:36 pm |
TPerkins
Joined: Wed Jan 02, 2013 12:59 pm Posts: 1793 Location: Clear Lake, Tx
 Re: Boat won't get on plane question.
What type of boat?
| Tue Jun 30, 2015 11:52 am |
Quack N Stack
Joined: Sat Dec 15, 2012 9:43 pm Posts: 2225 Location: Baytown, Tejas
Yeah what hull? Sounds like wrong transom heights maybe. Does the motor feel like its opening up to full power?
| Tue Jun 30, 2015 12:42 pm |
Terraboat
Joined: Sun Jan 18, 2015 10:46 am Posts: 288 Location: Northwest Louisiana
Rpm and trim?
_________________ 2014 PD 18x54 SBX w/ 36 EFI PD E5
| Tue Jun 30, 2015 12:52 pm |
t_corell
I had the same issue with an EFI motor. I could get on plane with just me, but it took longer then normal. It couldn't get on plane with a load. The dealer had to adjust the TPS and idle. Runs a lot better now.
Also, that "U" shaped hull isn't helping anything. It could be creating suction, creating the issue.
| Tue Jun 30, 2015 2:21 pm |
thehitman
Yea def check your transom height and angle along with your rpm range
| Tue Jun 30, 2015 3:09 pm |
thehitman
Is it a short transom or tall transom Motor ? Then go measure your transom you have on your boat and give us some RPM ranges and we can give you a better idea of what MAY be going on
| Tue Jun 30, 2015 3:11 pm |
BassmasterCia
Joined: Sat May 10, 2014 5:50 pm Posts: 660 Location: Arkansas
The "u" might help if its turned the right way lol. "v" is good "^" not so much..
_________________ 15x36 Go Devil Duck Skiff with a Go Devil Longtail.
| Tue Jun 30, 2015 4:44 pm |
brstanle
Joined: Sun Oct 05, 2014 12:27 am Posts: 659 Location: SETX/Houston
Is it some manner of flat-bottom boat? Weird things happen when that water stream gets interrupted going to the prop.
_________________ 35 GTR w/ 1860 GoDevil "Ironsides"
| Tue Jun 30, 2015 9:23 pm |
cheniermudder
Joined: Mon Apr 06, 2015 8:30 am Posts: 434 Location: SW Louisiana - Sabine River
First things first...is this a new boat ( never ran before)? Is it something that just started happening? If you wee running fine previously, then something is up with your motor. Have you made any recent changes to the trim location? If you're set too low, that may be part of it. How much weight do you have in the back vs front? If you've looked at these, then you may need to have someone take a look at your motor.
_________________ 2010 31hp GT on a 1648 Alumacraft Jon Boat
| Wed Jul 01, 2015 8:16 am |
Quack N Stack
Back to the first two posts...what type of hull is it and do the transom measurements match.. Get those 2 things and the problem will likely be solved pretty quickly
| Wed Jul 01, 2015 8:38 am |
Waterfowl Fool
Joined: Sat Jan 14, 2012 8:58 pm Posts: 354 Location: Okeechobee - Florida
Post up a pic of your transom
_________________ Proud to have served; USMC 90-94 I earned it VFW - Life Member
REPORT STOLEN VALOR !!
| Thu Jul 02, 2015 7:07 am |
Jduck031
Check the pitch of your prop. I have a 2015 gt and for some crazy reason it came with a 12p prop instead of a 10p. It should be scratched into the prop somewhere, may have to take it off and look closely.
| Sat Jul 04, 2015 3:28 am |
willett
Joined: Wed Jan 14, 2009 10:22 am Posts: 1764 Location: Tyler, TX
We didn't build the boat but did some major modifications to it right after he had it built. He never even had a motor put on it and brought it to us to "Fix" some things.
Hunt Deck was all jacked up and transom angle was wrong so we completely rebuilt the transom and hunt deck. Transom angle is exactly as I build my boats and what GT has always told me, 21" Tall and 20 Degrees.
With me by myself boat gets on plane but the nose and bottom bounces like crazy and barely getting 24-25 mph out of it at 3900 / 4000RPM with the info he described above.
_________________ Pete Willett WC Custom Boats - Tyler, TX http://www.wccustomboats.com
WC Custom 2048 3/16 Bottom Center Console with 35 PD EFI GTR WC Custom 1840 Hybrid 3/16 Bottom with 37 EFI BOSS
| Sat Jul 04, 2015 12:45 pm |
willett
Hull is 1 piece 3/16 and motor is brand new tall transom
| Sat Jul 04, 2015 12:53 pm |
OwenDickeson
Honestly to me he is probably pretty close to what it should be running. You can't compare the speeds people get from the tin can gatortail boats to an all 3/16th 18x60 hull. Plus if the bottom is already crowned, then there is not much else you can expect. Maybe a perfectly flat hull might do 27-28 mph??
| Sat Jul 04, 2015 4:35 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
I'm kinda with Owen on this one. Willet, what was wrong with the hunt deck and transom?
| Thu Jul 09, 2015 8:56 pm |
