extreme series vs x-series hull https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=62667 |
Author: | redfisher3 [ Tue Jul 14, 2015 9:18 am ] |
Post subject: | extreme series vs x-series hull |
Not trying to start a GT vs. PD argument, just have a couple questions that I was not able to find searching. First off, I’m looking to buy a 1754 center console with a 37 and hydraulic steering, no matter which one I buy. My questions are, first off, which hull is seen as being a better built hull (x-series vs extreme). Second question is, which package would be better at carrying a load? I do a lot of bowfishing, so it will be loaded down quite a bit, just wondering which package would accommodate that better. Thanks. |
Author: | msm8281 [ Tue Jul 14, 2015 9:30 am ] |
Post subject: | Re: extreme series vs x-series hull |
The X series is just a standard square chine hull. The exteme hull is a special crimp on the bottom to help the boat turn better at faster speeds without sliding as much. They will both carry a load similar. Just get an 18x54 if you plan on doing a lot of bowfishing in either. |
Author: | redfisher3 [ Tue Jul 14, 2015 9:33 am ] |
I'm kind of stuck on the size I believe. Boat has to fit in the garage and it will be tight as it is. I will already have to modify trailer to swing away |
Author: | Terraboat [ Tue Jul 14, 2015 9:51 am ] |
If you get an 17x54, expect to have to do engine mods I you have a heavy front end bowfishing load. |
Author: | redfisher3 [ Tue Jul 14, 2015 10:01 am ] |
Would 1' really make that big of a difference? Can anyone comment on the build quality of both hulls? Is one build better than the other or are they both quality hulls? |
Author: | txmudcutter [ Tue Jul 14, 2015 10:03 am ] |
Author: | North LA Hunter [ Tue Jul 14, 2015 10:03 am ] |
Both hulls are built well and broke up by the same people. Just a little different bracing. I would say the pd hull has ( not sure if they're still building them the same) more bracing, but then the extreme will turn better and maybe a tad bit faster. I think both are good quality hulls the will work fine. Size is all up to you and what you use it for if your not going in tight places, I would say go as big as you can as long as you don't want to break any speed records. I like to run 20' boats for hauling a load. And I run a lot of timber so I try to stay between 48-54 wide. Sent from my beeper |
Author: | mizzippi jb [ Tue Jul 14, 2015 10:06 am ] |
I was thinking that the newer pro drive hulls had a bit of a taper in the back. I know Buddy's does, versus Will's old boat which was a year or 2 older and a straight square chine hull Sent from my XT1254 using Tapatalk |
Author: | North LA Hunter [ Tue Jul 14, 2015 10:56 am ] |
Author: | Terraboat [ Tue Jul 14, 2015 11:14 am ] |
Author: | JIMMY W [ Tue Jul 14, 2015 11:15 am ] |
The Extreme makes an ass out of them all.Thats a fact jack |
Author: | Terraboat [ Tue Jul 14, 2015 11:22 am ] |
Go test drive them. Bring about 4 or 5 empty ice chest with you and a 5 gallon bucket. Test drive them empty, half load, and all the way loaded (1000 to 1200 lbs). Make sure to put weight up front similar to your estimated load ( lights, trolling motor battery and one dumb ass who will always sit there ( usually the fatest guy). I think it's better to have engine work, then have to shift the weighty around or tell guest my 20G rig won't haul the load. Much better to have them ask you to slow down out of fear then laugh at your weak ass rig. ![]() |
Author: | TooTall [ Tue Jul 14, 2015 12:09 pm ] |
Author: | North LA Hunter [ Tue Jul 14, 2015 12:53 pm ] |
Author: | TPerkins [ Tue Jul 14, 2015 1:42 pm ] |
I thought they created lift? Is that not true? Sent from my SM-G900V using Tapatalk |
Author: | SETx Longtail [ Tue Jul 14, 2015 3:16 pm ] |
Possibly but the only measurable amount of anything they create is shit talking on Internet forums. They do turn well but, to me there are too many variables to really say wether one is better than the other as far as carrying a load. Square/single taper is good and round isn't usually AS good, but both will get the job done. As far as one, two, three, thirty six, extremeish, pizza cutter, etc chines... I dont know... It usually all comes down to the surface/planing area of the hull and weight distribution. |
Author: | Terraboat [ Tue Jul 14, 2015 3:51 pm ] |
^^^ this ^^^ The only thing extreme about that boat is the name. A flat bottom boat is a flat bottom boat. Now, you can screw it up easy with wrong motor height and angle, but these boat builders have all optimized their boats. Then it becomes a less weight game. |
Author: | Putt putt [ Tue Jul 14, 2015 4:32 pm ] |
Like everyone has already said 18' is the way to go with a single engine. Both boats will be so close in speed with that load that you shouldn't compare speed. However when your fishing or whatever you plan on doing with this boat. You have to decide what type of reverse system you want. In my opinion prodrive has the better engine. Gatortail has a better boat, with all there custom options. Best thing you can do is ride in both and decide. |
Author: | tchauvin [ Tue Jul 14, 2015 4:48 pm ] |
Author: | mizzippi jb [ Tue Jul 14, 2015 4:51 pm ] |
I own an extreme hull and I love it. It's actually an older model (2010) and it turns well. Don't know why gt didn't stick with that design. Probably too expensive to carry the crimp all the way to the front. But I had a go devil boat one time and you ain't gonna beat the way a round chine turns. Period. Sent from my XT1254 using Tapatalk |
Author: | jerimiahw [ Tue Jul 14, 2015 5:40 pm ] |
I had an xseries also tough ass hull my only complaint is that the floor didn't go all the way to the sides. always head grass and shit stuck in it .my next hull will be wall to wall on floor ,I like the gtr hull and prodigy ,it will be one of the two |
Author: | mizzippi jb [ Tue Jul 14, 2015 5:52 pm ] |
Author: | SpecialK [ Tue Jul 14, 2015 7:08 pm ] |
Author: | JIMMY W [ Wed Jul 15, 2015 3:50 am ] |
