Rolling on the GG! https://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=4&t=63024 |
Author: | fredbear012 [ Mon Aug 03, 2015 1:10 pm ] |
Post subject: | Rolling on the GG! |
Time to see what this Gator Glide stuff is all about! Got the motor pulled off, flipped and Gator base applied. Unfortunately I won't be able to apply the G4 for another 2 weeks due to work and what not. Ready to try it out! Sent from my SAMSUNG-SM-G870A using Tapatalk |
Author: | JD145 [ Mon Aug 03, 2015 1:26 pm ] |
Post subject: | Re: Rolling on the GG! |
tie her down good! ![]() |
Author: | fredbear012 [ Mon Aug 03, 2015 1:38 pm ] |
Haha hate to loose her at the ramp! Sent from my SAMSUNG-SM-G870A using Tapatalk |
Author: | BlueShamu [ Mon Aug 03, 2015 1:41 pm ] |
Keep the winch cable hooked up until she's in the water. Keep a taught rope wrapped around the winch post so you can unhook the winch without giving yourself a black eye. Double wrap it so you can let her slide down the trailer and I to the water. Good luck! Sent from my iPhone using Tapatalk |
Author: | fredbear012 [ Mon Aug 03, 2015 2:48 pm ] |
Thanks! That's a good idea with the rope! Sent from my SAMSUNG-SM-G870A using Tapatalk |
Author: | DmaxHunter [ Mon Aug 03, 2015 4:06 pm ] |
Yeah, the stuff is super slick. Take it easy when you first get in the shallows, takes half the effort to get it moving. |
Author: | cheniermudder [ Mon Aug 03, 2015 4:56 pm ] |
I'm considering putting G2 on my jon boat. Would appreciate a before and after comparison report on how it changed your boat's performance (realizing it'll be a few weeks before you can test it out). |
Author: | fredbear012 [ Mon Aug 03, 2015 6:04 pm ] |
Author: | kcudslayer [ Mon Aug 03, 2015 6:10 pm ] |
just tested my buddies allweld john with chines and you can stop and start in thick reeds about a foot out of the water in 1 foot of water with ease its some good stuff |
chines..... i meant ribs |
Author: | fredbear012 [ Tue Aug 11, 2015 6:58 am ] |
Ended up getting some spare time off, finally got the G4 ROLLED ON. But after I finished and peeled the tape almost all the residue was left from it. I ran out of time to sit there and Jack with it. Anyone have a good idea as to what would take it off? I was thinking use the left over acetone. Sent from my SAMSUNG-SM-G870A using Tapatalk |
Author: | stu [ Tue Aug 11, 2015 7:09 am ] |
Mine didn't do that but I used G2. Send Frog a PM. Sent from my iPhone using Tapatalk |
Author: | fredbear012 [ Tue Aug 11, 2015 7:13 am ] |
Author: | SETx Longtail [ Tue Aug 11, 2015 9:43 am ] |
Try some goo gone or similar citrus remover. The acetone will likely hurt the other paint on the boat. |
Author: | JD145 [ Tue Aug 11, 2015 10:08 am ] |
Author: | stu [ Tue Aug 11, 2015 10:22 am ] |
Author: | Frog [ Tue Aug 11, 2015 11:23 am ] |
The raised roller (about half the roller above the bunk) really solves the load unload thing. ( see pic below) . 3m adhesive remover works best for taking of glue. It's a mixture of xylene and acetone and a conditioner from what I understand. Always best to pull the tape on last coat of base and or GatorGlide. Leaves a much straiter wet edge and is easier to clean up anything that may have wicked underneath. |
Author: | 13 pistols [ Tue Aug 11, 2015 12:49 pm ] |
looking to do the same on my boat . . . . got a 1548 . . .what size boat you have and how much G4 did it take to do it? Number of coats? |
Author: | fredbear012 [ Tue Aug 11, 2015 3:23 pm ] |
I Will try the goo gone and 3m adhesive remover This wknd on it hopefully its not to late. Also that's actually a pretty good idea with the roller above bunkers might be my next project rather than having to tie and untie it every time I launch. As for 13 Pistols it's a 17x54 went 5 inches from the bottom of the boat, one kit (half gallon of GB & half gallon of G4) did 4 coats of GB, and 4 coats of G4 Anchor. Used every last drop too. Sent from my SAMSUNG-SM-G870A using Tapatalk |
Author: | med [ Tue Aug 11, 2015 3:36 pm ] |
Rubbing alcohol works too |
Author: | fredbear012 [ Sun Aug 30, 2015 8:02 pm ] |
Sorry for the late feed back, tape residue came off with a little elbow grease and goo gone. The GG on the other hand is awsome had no problem loading my boat back onto trailer with the wench dry. Also noticed I can load it on the trailer w/o the boards in the water. I know for a fact that wouldn't ever had happened before! So far it gets a 5 star from me now to see how long it lasts. Sent from my SAMSUNG-SM-G870A using Tapatalk |
Author: | Frog [ Tue Sep 01, 2015 7:53 am ] |
Tie it down good before you trailer it anywhere! I know its been said a lot but not enough. A guy just untied his boat at the top of a ramp and off it came. |
